2001 1500-system too lean bank 1
Old May 24, 2010 | 02:23 PM
young1014's Avatar
young1014
Default 2001 1500-system too lean bank 1
engine light came on, code reader said system too lean(bank1) anyone know what i need to do to fix it? truck bogs out and barely moves when trying to accelerate.
Old May 24, 2010 | 02:31 PM
First thing I would look at is fuel pressure. If that's ok, might be an O2 sensor on its way out. Possibly a plugged/dead injector as well. Do you have a miss at all?
Plugged cat?
When is the last time you did a tuneup? How many miles on the truck?
Old May 24, 2010 | 02:35 PM
young1014's Avatar
young1014
well i had a previous code for cylinder seven misfire but thats no longer there, truck has 100 000. going to clean injectors and check that cat out today, see what happens from there.
Old May 24, 2010 | 02:36 PM
Sounds like a plan. Let us know what ya find.
And, (belated) Welcome to the forums.
Old May 24, 2010 | 02:37 PM
young1014's Avatar
young1014
thanks will do! and no tune up yet, just got the truck!
Old May 26, 2010 | 01:01 AM
chogg's Avatar
chogg
I had the same issue with my 96 when I first got it 2 months ago turned out to be the fuel pump. might want to look into that.
Old May 26, 2010 | 08:52 AM
95RAM360's Avatar
95RAM360
if its running lean, that would be an 02sensor...(im a mechanic, ive dealt with those codes MANY times.) and since it says bank 1, thats a dead giveaway....Bank 1 is the Pre-cat sensor.
