small project pitcures
Old May 30, 2010 | 11:41 PM
canada_rokzz's Avatar
canada_rokzz
Default small project pitcures
Painted the diff cover last week, and never did show a picture. Here is a picture and the process...
  1. Wire wheel all the cr@p off the cover
  2. Spray it with brake clean to get all the grease off
  3. Spray two coats of your choice of paint
  4. Let dry
  5. Install with RTV between the cover and diff...
My CB antenna install:
I grabbed a small piece of aluminum, and bent it to fit. It started out about 8 inch's long and 1 1/2inch's wide, and after bending here is the resulting mount. I think I may have to re do it though. It may whip in the wind more than I want...
Now onto relocating my trailer brake controller.
It came with the truck, but did not have a mounting bracket. I also have a ashtray that won't get used... Besides that it was broken on the back so I could not even use it as a change holder. So I thought to myself, "will it fit in the ashtray?"
Here is the rough fitment picture...
I started die grinding the ashtray so the brake controller will protrude out the front. If it does not work, then off to the wrecker for an ashtray and I make a bracket for the controller... Time will tell...
Old May 30, 2010 | 11:52 PM
GeorgiaDodge's Avatar
GeorgiaDodge
i wanna see this ashtray mounted brake controller. never thought of that but sounds awesome
Old May 30, 2010 | 11:58 PM
canada_rokzz
At the least it will be different. I will post a pic with the success or the failure...
Old May 31, 2010 | 12:00 AM
BIGRED97's Avatar
BIGRED97
good luck finding an ashtray. i looked forever and couldnt find a good one. and nobody had one. finnaly found a broken one that i could glue together and it works.
some chumps stole mine when my truck got broken into last year, WHY TAKE THE ASHTRAY??
Old May 31, 2010 | 12:01 AM
It isn't nailed down.
Old May 31, 2010 | 12:38 AM
BIGRED97's Avatar
BIGRED97
and it had about 5bucks in change, and the remote to my stereo. but didnt mean to threadjack.
brake controller in the ashtray looks good, but may be a lil tight.
canada_rokzz
If not, then I just make another aluminum cover like the one on the cup holder. Its not a huge worry on one side or the other.
