Truck running hot
Old Jun 2, 2010 | 01:41 PM
97tn4x4's Avatar
97tn4x4
Default Truck running hot
I was on the way to pick my son up and I noticed my truck was running hot. It's running with the needle at the 2nd 0 on 200. It's full of coolant the water pump and t stat are only 5 months old. Anybody got any ideas?
Old Jun 2, 2010 | 02:12 PM
Your engine will run right around 210*, even though it comes stock with a 195* thermostat. If ambient air temp is up there, it will run a bit hotter.
Old Jun 2, 2010 | 02:27 PM
97tn4x4's Avatar
97tn4x4
It's about 94 or so out today. It's never run this hot before though. I'm gonna try to flush the system out today.
Old Jun 2, 2010 | 02:35 PM
1998ram5.9's Avatar
1998ram5.9
sometimes a thermostat will only last a month or so.I had the same thermostat in for a year and a half, changed it then i went through 3 of them in 5 months. So sometimes it a hit or miss getting a goodthermostat. Good luck
Old Jun 2, 2010 | 03:26 PM
97tn4x4's Avatar
97tn4x4
I was squeezing the upper radiator hose and i could ear the thermostat moving up and down. Now correct me if im wrong but that shouldnt happen right?
Old Jun 2, 2010 | 03:40 PM
UnregisteredUser's Avatar
UnregisteredUser
That shouldn't happen.
Old Jun 2, 2010 | 03:51 PM
97tn4x4's Avatar
97tn4x4
i didnt think it should. so im gonna start with that this weekend.
Old Jun 2, 2010 | 05:11 PM
ryan0714's Avatar
ryan0714
i can tell you right now its ur thermostat. i had same exactly problem when i drove from oklahoma back to south carolina. halfway it started goin up and then rested at over 200 but never went up more. it would flux back down to like 190 then go back up over 200. i went straight home replaced the thermostat with a 180, and i have not had it even think bout movin over 180 since.
Old Jun 2, 2010 | 06:35 PM
97tn4x4's Avatar
97tn4x4
Where areyall getting your 180 tstats at? Any particular brand?
Old Jun 2, 2010 | 07:11 PM
dodgeman52's Avatar
dodgeman52
if u go to auto zone there motorraids which are good t-stats in my exprenice
