Quick question about changing gear oil....
Old Jun 4, 2010 | 12:15 AM
CPTAFW163's Avatar
CPTAFW163
I used a gasket. Peace of mind type of thing. A gasket costs about as much (maybe a bit more) than the big bottle of ultra black.
I highly recommend you using 50% lucas oil stabilizer and 50% valvoline synthetic gear lube. THe lucas oil has an anti foam which is what the limited slip additive is. You can even go 100% lucas oil stabilizer, however it is VERY thick and hard to get in there.
Or, you can just get a hand pump and pump the oil out then put more back in. No dis-assembly required!!!
Old Jun 4, 2010 | 12:18 AM
95RAM360's Avatar
95RAM360
i went all gear oil....but i dont have the LSD, so the anti foam i dont really need right?
but i went 80w90 mobil 1 synthetic gear oil, it felt like a cleaner ride....but everytime i do a repair my mind tells me "it runs sooooo much better" lol
Old Jun 4, 2010 | 01:30 AM
truegent81's Avatar
truegent81
yeah we dont need the anti foam if our diff is open. i used 80w90 valvoline on mine.
Old Jun 4, 2010 | 01:37 AM
CPTAFW163's Avatar
CPTAFW163
I noticed a smoother ride after my change. I am convinced that time is more of a factor than miles. After a while,. the oils get tarnished.
That is why my oil changes are every 3 months OR 3K miles. You can alternate synthetic and dino oil if you are changing that regularly. but in all honesty, if you are changing oil every 3 months OR 3K. Then you can just use ANY dino oil.
--Dan
Old Jun 4, 2010 | 01:55 AM
BlueBeast2's Avatar
BlueBeast2
Shop didn't wait anytime when they pulled my cover and resealed it cause it was leaking a little. They also said we don't like using the gaskets we use the gasket maker it works better.
Y'all think I should use 80w90 with my eaton posi? I need to replace the chrome cover one if these days need to know what to put back in
Old Jun 4, 2010 | 02:03 AM
CPTAFW163's Avatar
CPTAFW163
I have heard that people use the 140W for the rear if you tow regularly. I think i read that in the manual. I still have my manual for my 2001.
Old Jun 4, 2010 | 02:09 AM
truegent81's Avatar
truegent81
yeah 140 for towing, other than that 80w90
