Quick question about changing gear oil....
Old 06-03-2010 | 10:03 PM
Whaack's Avatar
Whaack
Default Quick question about changing gear oil....
Gonna change my rear gear oil tomorrow. Going to add the friction additive cause I know I have a LSD but I am also going to use black RTV for the seal.
I had heard that I have to wait 24 hours to let the RTV set before I can refill the differential with new gear oil but the FSM doesn't say anything about that. It just says to install within 5 minutes of setting up the RTV.
Do I have to wait or is that incorrect info? Also the FSM says 30 ft/lbs per bolt, that seems a bit much to me?
Old 06-03-2010 | 10:23 PM
truegent81's Avatar
truegent81
i actually just did my diff last month. the only thing different is i had an open diff. as for the gasket you wanna seal with, i used "the right stuff" which is an instant gasket maker. with RTV it has a curing time of 24 hrs right? i believe you have to let it sit before you can put it up to the assembly and start tightening it. the wait time before you start tightening is like 5 mins. and for torquing, i just hand tightened in a criss cross manner. once they were threaded cleanly and in a cross manner, i tightened with a wrench. i didnt use a torque wrench though.
Old 06-03-2010 | 10:28 PM
For RTV as gasket replacer, I just run a bead around the gasket surface, let it 'skin over' (5 to 10 minutes, depending on conditions...) and reassemble, add fluid to full. Never had a leak.
Old 06-03-2010 | 10:32 PM
truegent81's Avatar
truegent81
skin over is a good description for how long you should wait for you assemble..
Old 06-03-2010 | 10:39 PM
Whaack's Avatar
Whaack
So I was planning on using Permatex Ultra Black RTV. I should be good to go after an hour you think?
Old 06-03-2010 | 10:48 PM
I wouldn't even bother waiting that long. If you wanna wait about ten, put the cover on, and tighten up the bolts, and then take a coffee break, that works too.
Old 06-03-2010 | 11:43 PM
Whaack's Avatar
Whaack
Hey Truegent, is that you in your sig photo? If so that is BAD ***!
Old 06-03-2010 | 11:55 PM
truegent81's Avatar
truegent81
lol. no it is one of my numerous favorite clippings i have. if you want though, i can get the saw and ipod and take a pic for you as i sit on my cot lol. it is a pretty sick pic though...i do have lots of army pics of me but not this one
Old 06-04-2010 | 12:04 AM
Whaack's Avatar
Whaack
That's a sweet pic anyways! Thank you for your service, it is much appreciated! Stay safe.
Old 06-04-2010 | 01:08 AM
95RAM360's Avatar
95RAM360
when i changed my rear diff fluid, i put on the rtv, immidiatly put on the cover and torqued....waited 10 minutes, filled it with gear oil, took it for a ride....this was about 6K ago, and ive done alot of off-roading since, and i havent lost a drop, nor is it contaminated.
