tension on mirrors
Old Jun 6, 2010 | 04:16 PM
plumbob1968's Avatar
plumbob1968
Default tension on mirrors
is there a way to tighten the tension on the side mirrors.....driving down the highway the mirrors turn into the windows...did a search but really didnt find a answer
thanks for any help
Old Jun 6, 2010 | 04:39 PM
Can't find a good picture of it.... but, if you take the mirror off the truck, there should be a strap type arrangement, or some such, that holds the shaft in place. If it is just bolted there, you should be able to tighten it. Take it off, have a look, take it from there.
Old Jun 6, 2010 | 05:21 PM
plumbob1968
so that means i have to take the door panel off right to take the mirror off? gonna wait a few days then to do that one gotta put new speakers in the doors and dont have them yet....guess i will hillbilly fix it till then shove a few toothpicks around the hole where the mirror goes in will tighten it up till i take it apart lol
Old Jun 6, 2010 | 05:30 PM
Yep. Inner door panel needs to come off to find the screws that hold the mirror on.
Old Jun 7, 2010 | 09:50 AM
Sheriff420's Avatar
Sheriff420
Toothpicks are a good idea for a temporary fix. I'd probably just duck tape them.
Before you remove those panels you might want to get a pack of new clips, they tend to get mangled pretty bad when you pop them out.
http://www.clipsandfasteners.com/Tri...s_p/a19213.htm
I believe it is 13 clips in the front door and 7 in the rear.
Old Jun 7, 2010 | 11:11 AM
truegent81's Avatar
truegent81
+1 on the website!
i bought a new driver mirror for my truck last year off of ebay for $40. if you were to go this route, be careful of the brand you get. my mirror looks exactly like the OEM one, however; the mirror is built a little weaker and the mirror vibrates little more than the heavier OEM. you can find OEM on ebay especially used from dodge owners. if i would of found one at the time, i would have gone that route. also try LMC. for a new heated/electric one its $90..
Old Jun 8, 2010 | 12:53 AM
99dodge318's Avatar
99dodge318
are they tow mirrors? cause i know lmc sells some kind of sandwich plate for 1/2 tons who dont have tow mirrors but want them.
