Hemi Swap into a 2nd Generation Ram
Old Aug 5, 2011 | 01:45 PM
  #111
DDIRI's Avatar
DDIRI
I did buy the ecm from you.
Old Aug 5, 2011 | 01:49 PM
  #112
HemiDak-Quad's Avatar
HemiDak-Quad
If so The Vin Number is, 1D7HU18D83J658108..I thought I sent you the ECM and TCM, for a 2003 Dodge Ram .
Old Aug 5, 2011 | 01:53 PM
  #113
DDIRI's Avatar
DDIRI
You did. I guess because the hemi I swapped in had come with skim. When I plugged it in and tried to start it the transponder on the steering column wrote the software to the ecm you had traded me. I had the computer Vin flashed to the donor truck I got the Hemi from. Because I used the dash from the hemi I had to match the mileage too.
Old Aug 5, 2011 | 01:58 PM
  #114
HemiDak-Quad
I think - IF you take you're truck to Dodge they will program that VIN Into you're system and make the truck recognize the ECM. Someone told me I would have to do that with mine , But I didn't have to.
I don't think that ECM has a security system. When I installed mine , The security system didn't go through the computer.. BUT I didn't have a coded key either..I used the key switch in the Dakota to run the truck , and I didn't mess with any of the dash or change the PDC..You might be able to change the ignition switch over to a non security switch, I don't know how that works ??
Old Aug 5, 2011 | 02:03 PM
  #115
HemiDak-Quad
"I'm Pretty Sure". The VIN has to be the one that the ECM came from. You're making the computer think it's still in the truck it came out of..
Old Aug 5, 2011 | 02:05 PM
  #116
DDIRI's Avatar
DDIRI
I found a mobile guy to come program the ecm for me cost me 35 bucks the dealer wanted 600. The way the Skim security system works is the computer looks for the skim code in the key and the transponder sends it. I guess once the computer has had security activated in it you have to have a dRB3 scan tool to remove it. The dealer won't do it. I found a couple places online that will remove the security from the computer. Prices to remove it range from 125 to 150. I'm just going to find someone to program chip keys for me. Just need money ha ha
Old Aug 5, 2011 | 02:07 PM
  #117
DDIRI's Avatar
DDIRI
Yeah my understanding from what I read was that the motor won't work if the Vin for the motor isn't programmed into the ECM. I'm not sure though. I could be wrong.
  #118
HemiDak-Quad
Any way- I hope this helps, I was going to send you that a long time ago , But some but-hole sent me a KILLER Virus in my mailbox , I guess , and it crashed my computer so bad I can't even turn it on. I had to buy another computer. I didn't have the money so it took a while to get back online...
Old Aug 5, 2011 | 02:08 PM
  #119
HemiDak-Quad
Dodge Should know, but it won't hurt to have all the Vins anyway..
Old Aug 5, 2011 | 02:10 PM
  #120
DDIRI's Avatar
DDIRI
Yeah I appreciate it. In any case if it does need to be the Vin from the ecm I have that Guy who does it for cheap. I still need to finish swapping my valve springs, find the TB air hat ring seal, and finish my brakes, and figure out the rear tail lights.
