Hemi Swap into a 2nd Generation Ram
Old Jan 9, 2012 | 06:14 PM
  #211
HemiDak-Quad's Avatar
HemiDak-Quad
What did you do to the truck today. Hopefully you threw a full charge on the battery , Reset the ECM , by grounding the Pos (+) Battery wire to the frame for 30 seconds , and checked all the grounds..
Try it if you haven't already..Did you borrow the OBDII ? We'll figure this out , one way or another..You might have to start trouble shooting wires by going through my old Dakota thread .. Don't get discouraged budy "You'll get it"...
Old Jan 10, 2012 | 06:00 PM
  #212
DDIRI's Avatar
DDIRI
I got the obdii scanner but I haven't got a charge on the battery yet to use it. I am going to. Take it to auto zone in thé morning have them test it and see if its ok. I checked all my grounds they all were fine. I will post up as soon as I get a scan on the computer. The trans not shifting out of second is the thing I can't understand right now. Truck is getting fuel and air. I will check spark tomorrow.
Old Jan 11, 2012 | 02:08 AM
  #213
HemiDak-Quad
Very Cool , Re~Set those computers after you get the battery right..If you need another TCM I'll send you one , I wish you lived closer I'd come over and take a look at it..Good Luck I wish I could do more..
Old Jan 11, 2012 | 01:55 PM
  #214
DDIRI's Avatar
DDIRI
So this is where I'm at as of this morning.
-Went to Auto Zone got my old battery swapped out for a new one.
-Hooked up OBD2 scanner I get ERPR message showing ( indicating there is no longer power at the vehicles DLC) indicates to check fuses and try again. No burned out fuses so I reset computer by grounding positive cable to frame while neg cable was connected.
I retry running the scanner to see if it will talk to the computer still getting the same read out.
I found a guy on CL last night parting out his 04 RAm says he will sell me his PDC and Trans cooler for $40 only problem is that he isn't around until next weekend. So we will see If it is the PDC.
I also can no longer shift the transmission it is stuck in second. I don't know if the Shifter Cable has worn out, I am assuming that it has because the shifter on the column moves but the cable at the trans doesn't. So I am unable to Start the truck because it is in second. maybe the guy will sell me his shifter cable too. Heck Maybe I will see if he will sell me his whole truck.
Hemi-Dak I find myself wishing you lived closer too. Ha ha You have been more than helpful I really appreciate it.
Old Jan 11, 2012 | 04:39 PM
  #215
BackwoodsRam's Avatar
BackwoodsRam
have you tried disconecting the lever from the trans and try to move the little shift arm at the trans itself?
Old Jan 11, 2012 | 06:59 PM
  #216
rapidtransitric's Avatar
rapidtransitric
you need to get that trans in park you will never be able to crank it over in gear
Old Jan 11, 2012 | 07:00 PM
  #217
DDIRI's Avatar
DDIRI
The shift cable is broken I'm about 90 percent sure the shifter moves but the lever doesn't I'm thinking of pulling the pan and doing a filter change and seeing if something is caught. Its strange I know the trans is low on fluid from the cooler line breaking I think maybe that's why it wonk shift and then when I tried to shift it to move it the cable broke.
Old Jan 11, 2012 | 07:03 PM
  #218
DDIRI's Avatar
DDIRI
This is really a headache of a project. I'm going to name my truck Murphy's Law. Ha ha ha. Rapid do you think low fluid would affecting shifting I know it did on my old turbo 400.
Old Jan 11, 2012 | 07:04 PM
  #219
rapidtransitric
which fuses did you check the ones inside the truck or the ones at your pdc? did you also check all your relays? did you do this with a test light or visually look at them to determine if they are good
Old Jan 11, 2012 | 07:14 PM
  #220
DDIRI's Avatar
DDIRI
The hemi only has one fuse panel. Its under hood those I checked and they were fine this is why I think the pdc is toast.
