Hemi Swap into a 2nd Generation Ram
Old Aug 28, 2012 | 03:12 PM
  #491
DDIRI's Avatar
DDIRI
Originally Posted by gdstock
So that means it will be back together this week? (heehee...)
If I could get the cam out it would.
Old Aug 28, 2012 | 04:38 PM
  #492
Physically remove the lifters from the bores. You can just set them next to the holes they go in......
I don't think there is anything else that could (should...) be holding the cam in.... thrust plate on the front??
Old Aug 29, 2012 | 10:01 AM
  #493
DDIRI's Avatar
DDIRI
That's what i was thinking is that the lifters are in the way. The thrust plate is off. It just feels so solid like something is really binding it up. The best pay it's that if the nonservicable bearings are jacked up i would have to buy a new block to fix it. No I'm really wondering why that cam sprocket bolt snapped.......
Old Aug 29, 2012 | 10:54 AM
  #494
From what I see, Mopar says they are non-serviceable, but, numerous other sites have them as available from the aftermarket, and changed just like any other cam bearing. (pressed in/out). According to one site that I read, the Durabond bearings have an EXTERNAL oil groove, to help out with oiling...... Never heard of them before, so, no clue if they are any good or not.
I suspect though, that if the bearings are indeed in need of replacing, you will have to pull the motor for the rearmost bearing......
Old Aug 29, 2012 | 11:44 AM
  #495
DDIRI's Avatar
DDIRI
I think if i have to do any more motor work I'm going to be over my head. Really ticks me off the guy i bought it from said yet was in good working order. It has been one problem after another. I am going to pull the cam and check out the bearings If they are trashed I'm either going to buy a replacement block or just swap a different motor in. I'm kinda thinking I bought a lemon.
Old Aug 29, 2012 | 12:17 PM
  #496
You HAVE had more than your fair share of problems with this swap...... Sorry man.
Old Aug 29, 2012 | 12:36 PM
  #497
merc225hp's Avatar
merc225hp
+1 This is right up there for troubled swaps that I have seen/done. Good for you sticking with it.
Old Aug 29, 2012 | 06:46 PM
  #498
Wombat Ranger's Avatar
Wombat Ranger
^^ Yea, that. You are the man.
Old Aug 29, 2012 | 07:23 PM
  #499
98hemi-ram's Avatar
98hemi-ram
X2 I can't believe all the problems you've run into with this swap!! Sorry to see you have to go through this I lucked into a second hemi for a steal of a price so I'm hoping that between the 2 motors and trans I've got now I can get at least one of mine working!!
Good on ya for sticking with this swap though!! I'd really like to see you get it up and running!!
Old Aug 30, 2012 | 12:50 PM
  #500
HemiDak-Quad's Avatar
HemiDak-Quad
Well dude , this is one time I wish I would have been wrong when I said It sounded like you were having timing issues..That's not a big deal for older motors but for a Hemi it can be a disaster ..
I wish there was something I could do to help , but in this case brother you're on your own.. I really hope once you get that cam out the bearings aren't scorched to the block. In that case I think you would be better off finding a Junk yard motor with low miles..OR Maybe get a short block and transfer everything over..
Either way I wish ya luck bro I hope you get it figured out soon, I know you're ready to drive your creation and enjoy some of the hard work you've done..
"It's been Hell" , stick with it...
