Hemi Swap into a 2nd Generation Ram
Old Apr 2, 2011 | 01:42 PM
  #71
DDIRI's Avatar
DDIRI
I found the plug I just had no idea what it was for being that it wasn't plugged in to anything when I bought the donor
Old Apr 3, 2011 | 09:18 PM
  #72
HemiDak-Quad's Avatar
HemiDak-Quad
Did you hook up the wires like this ?
Old Apr 6, 2011 | 06:08 PM
  #73
bjarki's Avatar
bjarki
more pics! words are boring
Old Apr 7, 2011 | 02:00 PM
  #74
HemiDak-Quad
Here's something for you to look at...
http://www.youtube.com/watch?v=h0YWvZqIrEo
Old Apr 7, 2011 | 02:01 PM
  #75
HemiDak-Quad
Posi Trac needed for sure..
Old Apr 7, 2011 | 03:10 PM
  #76
DDIRI's Avatar
DDIRI
So it fires with starter fluid if you hold the key and crank it with the throttle open but then it dies when you stop cranking. So it won't start thought it was bad gas so I drained the tank that wasn't it. Thought it wasn't getting fuel but it is. I have the lightning bolt and the little red light flashing. Any thoughts would be appreciated. I'm wondering of the computer I have running it came off a transponder vehicle and my trucks key doesn't have a skim. I did have a transponder but I disconnected it.
Old Apr 7, 2011 | 03:30 PM
  #77
JDG103's Avatar
JDG103
check all the grounds...last time my little red light came on..i found out i had a bad ground
Old Apr 7, 2011 | 05:30 PM
  #78
DDIRI's Avatar
DDIRI
Is the red light the security light?
Old Apr 7, 2011 | 06:51 PM
  #79
95RAM360's Avatar
95RAM360
wow, excellnt job so far...i just saw the dash pics and that looks sick....grats on the baby, and good luck with keeping the thing started...lookig forward to more progress
Old Apr 7, 2011 | 07:45 PM
  #80
mrfarrell's Avatar
mrfarrell
red light is for the security system..so you have no skim module or grey headed key correct?what year pcm do you have?and is it the original that came with your wreck?
