I found 7 grease nipples...
Old Jun 12, 2010 | 04:50 PM
M Laborde's Avatar
M Laborde
Default I found 7 grease nipples...
on my truck's front end. None on the rear. I cleaned them all off so I could lube the truck but I need a flex-hose for some of them.
Anyway, am I close to the correct number or are more hiding from me under the grease & dirt?
Old Jun 12, 2010 | 04:55 PM
M Laborde's Avatar
M Laborde
Grease nipples sounds like a fried snack...
Old Jun 12, 2010 | 05:56 PM
ghost4321's Avatar
ghost4321
You found seven?!? I only found 2 on mine.
Old Jun 12, 2010 | 05:58 PM
1 on track bar, frame end.
2 on tie rod ends (1 on each)
1 on pitman arm?
1 on drag link
4 on ball joints?
Old Jun 12, 2010 | 06:40 PM
dhvaughan's Avatar
dhvaughan
my 4wd upper ball joints have grease fittings on the top.
the tops of the bottoms are covered up by the axles, so i suppose they don't have fittings.
my new Precision brand axle u-joints have fittings.
my track bar does.
my tie rods, drag link, and pitman don't. i guess they are original.
Old Jun 12, 2010 | 07:01 PM
ghost4321's Avatar
ghost4321
Only my drag link and pitman arm have fittings.
Old Jun 12, 2010 | 08:34 PM
beamwalker's Avatar
beamwalker
BINGO!
9 zerk fittings!
Old Mar 10, 2011 | 08:18 PM
M Laborde's Avatar
M Laborde
1 on pitman arm?
1 on drag link
4 on ball joints?
Originally Posted by beamwalker
BINGO!
9 zerk fittings!
SO, I'm revisiting an old thread of mine. I can still only find 7 zirk fittings. I guess I'm blind. Can someone diagram it out or show me on a picture?
Old Mar 10, 2011 | 11:53 PM
Which two on the list are you missing? Lower balljoints perhaps?
Old Mar 11, 2011 | 07:37 AM
Randy_W's Avatar
Randy_W
I found some greasy nipples once, but I was in Juarez!
