new ball joints (question)
Old Jun 12, 2010 | 10:17 PM
NAILS's Avatar
NAILS
Default new ball joints (question)
i have read every thread i can i find about ball joints. ive got my new upper and lower pressed in but when i try 2 tighten the nuts on them they just spin. can anyone tell me whats going on??
Old Jun 12, 2010 | 10:20 PM
mr freeze's Avatar
mr freeze
What is spinning,the whole ball joint assembly or just the shaft?
Old Jun 12, 2010 | 10:29 PM
calgaryman's Avatar
calgaryman
need to put presure on the ball joint. place a Jack under the steering knuckle and jack it up a bit. should be able to tighten.
Old Jun 13, 2010 | 12:18 AM
NAILS's Avatar
NAILS
yea 10-4 good buddy, did what u said and worked great!! thanks. in the morning i will do the other side.
Old Jun 13, 2010 | 12:24 AM
NAILS's Avatar
NAILS
anyone have any idea if my ball joints being bad would make my tires closer together on top?? thats the caster right?? or could it have something 2 do with the 2 inch wheel spacers i have on??
Old Jun 13, 2010 | 12:37 AM
GC99RAM's Avatar
GC99RAM
It's camber and yes it can
Old Jun 13, 2010 | 12:38 AM
GC99RAM's Avatar
GC99RAM
spacers and the ball joints...
calgaryman's Avatar
calgaryman
Glad that worked for you...
It is called Camber. Your wheels look like this? /---\
Might have a bent axle. see if your new ball joints fix that first. If your axle is bent easiest fix, is to get offset ball joints, as the Camber is not adjustable.
Old Jun 13, 2010 | 01:41 AM
NAILS's Avatar
NAILS
thats what my wheels look like,u can see it without the wheel spacers, but with them u can really see it. thanks agian and i will let u know tomorrow after i get the other side done. if the axel was bent wouldnt u be able 2 feel it when driving?? and wouldent it make it a pain in the *** 2 pull out put back in?? it came out eazy and went back in the same.
Old Jun 13, 2010 | 10:29 AM
Not necessarily. Bent in that fashion, it just alters angles a bit for the various parts. The seals are what will suffer for it.
Why are you running 2 inch wheel spacers? What size tires/rims do you have on there? And what is the offset/backspacing on your rims? Putting two inch spacers on a 5000+ pound truck puts some heavy loads on your wheel bearings. Don't expect them to last long.....
