oil preasure issue? this normal?
Old Jun 12, 2010 | 11:02 PM
dodgeman2289's Avatar
dodgeman2289
Default oil preasure issue? this normal?
oil preasure guage will go up and down even while driving goes from 40 or alittle more down to like 20-30 up and down all the time.. this normal i never really paid attention to it i just started noticing it when i was looking at idle it does it when its warmed up and sometimes when im driving
Old Jun 12, 2010 | 11:12 PM
gearjammer95's Avatar
gearjammer95
Mine does same thing and have 221,000 miles
Old Jun 12, 2010 | 11:18 PM
DukeSupes's Avatar
DukeSupes
I personally have not ran into this. But have read some of the other posts about this very issue. The common fix is replacing the oil pressure switch that is located next to the distributor. I believe that it will take a 1' wrench to take off. I am having to replace mine, just because I accidentally hit it with a vice grip. :P its a 32 dollar part at either oreilly or autozone.
Old Jun 13, 2010 | 02:42 AM
J McWillis's Avatar
J McWillis
I got one last week from oreilly for only 16 and some change. I also have a 95 though.
Old Jun 13, 2010 | 03:45 AM
dodgeman2289
thank you im about to roll over on 200,000 miles
Old Jun 13, 2010 | 03:46 AM
dodgeman2289
thank you ill look into it and most likely replace it hope that takes care of it
Old Jun 14, 2010 | 10:00 PM
matty675's Avatar
matty675
nah man it aint the sending unit. just an old engine. clearances have increased and oil pressure has dropped a shade over the years, just enough to where the gauge cant pick it up (5 psi). min idle pressure is 6 psi. dont worry about it mines got 170k and the gauge has been doin that for a year now
Old Jun 14, 2010 | 10:34 PM
Mine has 160k, and the oil pressure is quite stable. never less than 40 pounds, even at idle when hot.
Old Jun 15, 2010 | 11:10 AM
matty675's Avatar
matty675
it doesnt happen to all of them. many of em have the problem and many dont. im pretty sure even tho that gauge appears to be a "true" functional gauge it is no better than ford's dummy gauge with hi med and low. pressure at idle should be around 8 psi, whereas it indicates 40
Old Jun 15, 2010 | 11:30 AM
Old Dodge 1's Avatar
Old Dodge 1
Cool
When I was having some issues with the oil pressure fluctuating I started asking a lot of questions in here. After doing the research I was going to put a high flow oil pump in as well. One of the guys steered me in the direction of not paying attention to my dummy gauge inside the truck and talk me into installing a mechanical gauges because they're more accurate.
Before I installed my new oil pump the mechanical gauge was reading the oil pressure at 15psi at idle and it went as high as 25,35psi at normal driving speeds. My dashboard gauge was never the same readings and never got above 40? Even with a new oil pressure sensor switch.
So I ended up installing a standard oil pump. At idle speeds I'm around 35 to 40 psi and cruising speeds it is 65 and as high as 78 on a mechanical gauge. In my case I think my old pump was just worn out. I spent a lot of time cleaning everything and making sure the pickup screen was perfectly cleaned before reinstalling.
