Drop hitch
Old Jun 14, 2010 | 01:55 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Its not flaw I would like to think I drive pretty safe. My dad has a class A cdl so I under stand how to tow trailers.
Thank you jason.
Old Jun 14, 2010 | 02:19 AM
BlueBeast2's Avatar
BlueBeast2
You said you see guys with lifted trucks on the side BECAUSE they had to mash the pedal to stop. You mash the pedal in a stock truck with a trailer your gonna have issues.
A lifted truck with a higher center of gravity could roll without a trailer.
Bigger tires might be more weight for your brakes wasn't disputing that point. I was stating a known fact that again even with a stock truck the trailer is gonna add weight.
Main point is if you drive like a dumbass your gonna have problems
Max you've had how many accidents???? LOL just messing with ya (not really :-P)
Old Jun 14, 2010 | 02:36 AM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by TheBigRedOne
Larger tires tend to want to wander when towing, because of the larger surface contact with the road.
Sidewall flex is the culprit here. Taller sidewalls flex more, so will tend to wander more, and M/T tires with their big lugs will wander more still. Throw in a suspension lift that lengthens the lever (frame to axle distance) to which the trailer applies lateral force and you'll get more sidewall flex so more wander. And if you want some real excitement, exceed the load rating of steel wheels on the rear axle of the tow vehicle so they can flex, too.
The lightweight trailers that the OP is talking about probably won't cause him any trouble at all. But with heavier, longer trailers the combination of tall tires, big tread lugs, suspension lift, and possibly weak steel rims is just asking for trouble.
Old Jun 14, 2010 | 03:01 AM
dodge15004x45.9
Most of them where my own flat and did not involve other cars just tree.
Old Jun 14, 2010 | 03:04 AM
dodge15004x45.9
The biggest trailer I will pull is 16ft long the heavy one will be the dump.
Old Jun 14, 2010 | 07:00 AM
dhvaughan's Avatar
dhvaughan
i use a 6" drop mount from northern tool that cost about $20-25.
Old Jun 14, 2010 | 07:33 AM
DODGEPWR's Avatar
DODGEPWR
Oh my god man this is just rediculous...Whats wrong with you guys? The OP didnt ask for advice and for your ''opinions'' on towing... He just wanted some info on a drop hitch. He didnt ask you to tell him if he should tow with HIS truck..Why dont you just stop ruining his thread..Im done.
Old Jun 14, 2010 | 09:51 AM
redheadhunter21's Avatar
redheadhunter21
If the biggest trailer is 16' you could probrably get away with just one drop hitch somewhere around 5" or 6" drop, it doesnt matter how heavy the trailer is because your only going to want to put so much weight on the tongue and it seems like all the trailers you will regulary tow are fairly small
Old Jun 14, 2010 | 12:13 PM
TheBigRedOne's Avatar
TheBigRedOne
Some of us gave him no BS common sense advice, there's nothing wrong with that.
Old Jun 14, 2010 | 12:24 PM
dodgeboy1979's Avatar
dodgeboy1979
I've got the hitch Max, works great and i've towed up to 30' trailers loaded with mine........I didn't hit nothin lol
