Possible Fuel Pump Problem Help I May Be Retarded!!
Old Jun 14, 2010 | 06:42 PM
UnregisteredUser's Avatar
UnregisteredUser
I recommend that before going through the expense and bother of replacing the fuel pump, you should tee a gauge into the line to prove it needs to be done.
Old Jun 14, 2010 | 06:43 PM
gotta get the appropriate adapters, and hook the gauge between the fuel line, and the rail.
Old Jun 14, 2010 | 07:13 PM
dhvaughan's Avatar
dhvaughan
my 01 has a test port in the rail, but i'm not sure about your 97. i was looking at a test kit at Advance the other day, and it had a bunch of adapters and T's with the kit. unfortunately, it was more expensive to buy than i expected it to be. see if you can rent/borrow one.
Old Jun 14, 2010 | 07:29 PM
95RAM360's Avatar
95RAM360
my 95 has a port on the rail.....it should be on the drivers side, about midway on the rail
Old Jun 14, 2010 | 07:42 PM
chapmanjohnm's Avatar
chapmanjohnm
not on this one lol mine is a 97 5.2
Old Jun 15, 2010 | 01:37 PM
chapmanjohnm
seems to be a little worse today, I took it for a spin and seems to begin missing about 300 rpms earlier now..and now I notice a slight miss with a non WOT condition maybe 3/4 or so throttle...maybe whatever it is will just decide to give out so I can figure it out that way lol....
Old Jun 15, 2010 | 01:41 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Get the catalytic converter pressure checked.
Old Jun 15, 2010 | 02:10 PM
chapmanjohnm
I removed the front o2 sensor yesterday and it made no change to the miss lol it only caused the ever annoying check engine light to come on could the cat still be to blame?
Old Jun 15, 2010 | 02:11 PM
chapmanjohnm
In the event it is the fuel pump has anyone tried on of those $60 dollar jobs on ebay? I'd prefer not to pay over $200 if there is a cheaper route that would get me by for a while, but I understand you get what you pay for lol...
Old Jun 15, 2010 | 02:21 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Get the cat pressure tested first.
