do e fans work
Old 07-01-2010, 02:45 PM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
Originally Posted by 1998ram5.9
and mayber it will run cooler when i 4wheeling
If you do a lot of low RPM work like rock crawling, electric fans can make a huge difference. If you do a lot of that stuff with an auto trans, you might also consider relocating your auxiliary transmission cooler and dedicating some smaller fans to it. Automatics make a lot of heat when they work hard at low RPM.
  #42
Old 07-01-2010, 03:11 PM
RM_Indy's Avatar
RM_Indy
RM_Indy is offline
Originally Posted by lastrights
how much are the pullies and what the work involed in that ?
Forgot only good on 97 or older, 2pc after that due to press on water pump pulley.
206 at Summit
http://www.summitracing.com/parts/MCH-10510/
Quick Reply: do e fans work
