Have a few problems and questions...?
Old Jun 17, 2010 | 07:41 PM
sjake07's Avatar
sjake07
Originally Posted by UnregisteredUser
You probably ought to hook a mechanical oil pressure gauge to that engine to confirm the probability that your sending unit's bad. It's a common failure that presents the symptoms you've described.
If all you're after is to get the front level with the rear, go for a leveling kit. You can get a 2" leveling kit for under a hundred bucks.
yeah thats really all I'm after. its a plow truck and my DD.
Old Jun 17, 2010 | 07:57 PM
UnregisteredUser's Avatar
UnregisteredUser
Plowing, eh? Didja get the coil spring upgrade to go with the plow? That'll get you back about a half inch or so right there and improve stability.
Old Jun 17, 2010 | 08:07 PM
lblair04's Avatar
lblair04
As for the leveling kit...I just installed a 2" leveling kit from hellbentsteel.com and they shipped it quick and it was a well made product. Only $65! Or, since you have a plow, my buddy used 2500 springs in the front and he is sitting level also, and it would beef up the front end.
Old Jun 17, 2010 | 08:39 PM
sjake07's Avatar
sjake07
thats what I have is a 2500. What if I used the springs from a diesel truck?
Old Jun 17, 2010 | 09:47 PM
dodgeman52's Avatar
dodgeman52
it might check and see if there different part numbers
Old Jun 17, 2010 | 10:02 PM
sjake07's Avatar
sjake07
the only difference is the 2500 is 7500gvw and the 3500 is 8800... so that would jack the front way up and not fun to drive... that just me thinking out...
Old Jun 17, 2010 | 10:04 PM
There were two versions of the 2500, 7500gvw, and 8800gvw. I have a 8800gvw version..... which means the 5200 pounds of dirt I had in the bed was only overloading it by about 2000 pounds.......
Old Jun 18, 2010 | 08:33 PM
sjake07's Avatar
sjake07
thanks!
Old Jun 20, 2010 | 07:58 PM
sjake07's Avatar
sjake07
here is another question. I found a a 360 for free and i would like to build it to put in my truck. will I have to change any thing else if i do this swap?
