brake controller
Old Jun 19, 2010 | 01:08 AM
chromed95's Avatar
chromed95
Default brake controller
Hey everyone. I'm looking to get a brake controller installed on my pickup. Straight forward question, which brake controller would any of you recommend, or do you have that works great? I'd like to install a progressive one versus one that only applies a constant amount to the trailer. The trailers I pull are pretty heavy when they have something in them or on them and I've been pulling them without the trailer brakes working (example that 4 place snowmobile trailer) which I'm pretty sure is a big no no if I ever got stopped by the troopers. I'm also after saving excessive wear and tear on my pickup brakes. Thanks guys!
Old Jun 19, 2010 | 01:51 AM
dodge15004x45.9's Avatar
dodge15004x45.9
This is the one I just picked up and my boss has on his and another friend has on his 2500.
http://www.amazon.com/Hopkins-Impuls.../dp/B000CMFUK6
You might want to buy this one. Its a little better for your needs.
http://www.etrailer.com/Brake-Contro...eid=2001106285
Old Jun 19, 2010 | 06:05 PM
chromed95's Avatar
chromed95
cool thanks buddy! Yeah that second one the Tekonsha P3 like you said is more of what I'm looking for. It's a little more expensive but that's expected I'm not worried too much about price. How do you like yours?
Old Jun 19, 2010 | 07:14 PM
dodge15004x45.9
Don't know it wont be here till wens and it gets installed on thurs. IDK when I will be using it of the most part I pull the smaller trailer (1 7/8 ball single axle). It will gets it test in the fall for leaf season.
The Tekonsha P3 is really advanced is will control each axle or the hole trailer. I think its good to like 5 axles which is way more than I needed. Plus I didn't buy it the boss bought it for me cause he can write it off for taxes.
I have heared any complaints from the Impulse. They said it works fine. Only time they had issue's with it was in the rain. They said it locked the brakes on the trailer a few times. How they corrected that issue was to turn down the amount of breaking going to the trailer.
With the 16ft trailer (5k gvw) with 2 60" exmarks and one 48" mower he runs it around 2- 2.5 depending on the hills. With 7yrds of wet mulch he goes about 4.
The features on the Tekonsha P3 are amazing it really thinks for you and adjust to the hills. You can change the colors on it and every thing. Might be worth getting.
I'm hoping a few other guys will jump in here and add there advice to the thread.
Old Jun 20, 2010 | 12:42 AM
pcfixerpro's Avatar
pcfixerpro
I really like my P3, matches the blue led dash Also worked great when I borrowed my buddy's 16ft trailer the other week. Even the lower P2? is a great option if your looking to save a few $. Provides the same breaking technique, but just less visual extra's.
Old Jun 21, 2010 | 02:49 PM
dodge15004x45.9
Here is mine installed. Name:  moto_0084.jpg
The wires where so short that I had to install it on the passenger side. I mounted it so I could see it threw the steering wheel.
Old Jun 21, 2010 | 03:56 PM
dodgeboy1979's Avatar
dodgeboy1979
https://www.southwestwheel.com/store...konsha-voyager
I've always liked these, they are simple to set (small dial on the side) and have never had one fail on me, ..... the price ain't too bad either.
Old Jun 21, 2010 | 06:32 PM
dodge15004x45.9
Most of them have the dial on the side.
Old Jun 21, 2010 | 06:45 PM
pcfixerpro's Avatar
pcfixerpro
not mine Yeah here is a cell pic of mine, and my two blue toggles I swapped in this weekend to get rid of my diamond plate switch panel I had been using.
Edit, for some reason the picture makes it look like it is mounted really low but it isn't that low.. :/ Must be because it is a cell pic.
Old Jun 21, 2010 | 07:44 PM
dodge15004x45.9
The nice thing about mine is I can grade it with one hand and turn it up or down. Just got back from testing it.
