My New Dodge
Old Jun 22, 2010 | 02:12 PM
RebelChewer's Avatar
RebelChewer
Default My New Dodge
It's a 95 Dodge Ram 1500 4x4 5.9l. I bought it for $600 and a plow for $900. It's got 122,333 miles on it. It came with a new radiator that I'll be installing and I just purchased new front shocks for it and a new battery. I tried to get it started yesterday with the new battery so I could drive it home (it's located at my boss's farm) but it wouldn't start. It sounded like it really wanted to, but just couldn't. It has been sitting since last summer when he purchased his new Dodge. I'm sure it's a fuel issue and my buddy thinks it might be the fuel filter. What do you all think?
Thanks,
Jeremy
Attached Thumbnails My New Dodge-95-dodge-ram-1500-001.jpg   My New Dodge-95-dodge-ram-1500-002.jpg
Old Jun 22, 2010 | 02:19 PM
Cool! Welcome to DF!!
Could be any number of things.... since it has been sitting for a while, might just be the gas has gone bad/accumulated too much water..... Did you try holding the pedal to the floor while you cranked?
Old Jun 22, 2010 | 02:25 PM
RebelChewer
Yea, I held it to the floor. I also added a few gallons of fresh gas with a little carb cleaner.
Old Jun 22, 2010 | 02:43 PM
dodgeram07's Avatar
dodgeram07
wow good deal
you can try sum starting fuild to see if you got spark
and welcome to DF
Old Jun 22, 2010 | 02:48 PM
RebelChewer
I also tried starting fluid. No good.
Old Jun 22, 2010 | 02:59 PM
dodgeram07's Avatar
dodgeram07
so then you have a problem with spark (or timing doudbt than if ran when parked)
i would look at and check the cap, rotor, coil, plug, wires
Old Jun 22, 2010 | 03:41 PM
RebelChewer
Ok, It did run when parked. I will check that, thanks.
Old Jun 22, 2010 | 04:21 PM
ryan0714's Avatar
ryan0714
+1 to ur spark, if it didnt fire with gas or starter fluid in the throttle body then u know right there that its not sparkin, id start with the plugs first, see if u can get it fired to get it home then u can complete the tune up later.
ryan0714's Avatar
ryan0714
also could be a corroded out wire, sorry to double post, but check them over too, good connections and all.
Old Jun 22, 2010 | 04:48 PM
RebelChewer
Ok thanks. I just tried to start it again with out starter fluid and it sounded like it didn't want to start at all. I'm going to have my friend come over in a few days and he'll help me get it running, and then we can do all the work to it.
