performance ignition coils
Old Jun 6, 2019 | 06:13 AM
  #21
Moparite's Avatar
Moparite
And it doesn't give you any more power. You get a smoother idle, and maybe a bit better throttle response, but, you are adding another layer of complication to the ignition system as well.
I wouldn't call it complication, It hooks up to the two wires going to the coil. They do wonders for carbed motors with EFI not so much but better than stock.
Old Jun 6, 2019 | 07:26 AM
  #22
I had one on my 88 Firebird Formula 350. (a torquey motor to begin with.) It started faster, idled smoother, but, that was about it. Till it failed, then it simply wouldn't run.
Old May 15, 2021 | 06:21 AM
  #23
David Rouis's Avatar
David Rouis
Default Performance coil
Originally Posted by 1999dodgeram
hey i have a 1999 dodge ram 1500 with the 5.2 and can't find a performance coil for it anywhere. accel makes an adapter so you can use their super coil but i was wondering if this would work for the msd blaster. has anyone tried this? here are links to the 2 parts
adapter - http://www.jegs.com/i/Accel/110/140021AH/10002/-1
msd coil - http://www.jegs.com/i/MSD+Ignition/121/8228/10002/-1
The adapter works for msd but for that ignition coil to last, you have to change the wires, plugs, distributor cap and rotor. I tried msd coil but it burned it up after an hour, it uses too much power
