engine swap help!
Old Jun 25, 2010 | 02:32 PM
dodgethefather_ramthedaughter's Avatar
Default engine swap help!
hey guys! i have a 318 in my 98 ram 1500, and i found a 488 that i want to swap it with. the v10 has 218xxxkm and the guy is selling it to me for 500$, is it worth it? and do i need to change my transmission and transfercase?
Old Jun 25, 2010 | 02:36 PM
Salex007's Avatar
Salex007
first off wrong section to post in, it will fit but you will need to get engine mounts, a new tranny, along with new wiring, it is worth it if you can do the work yourself
Old Jun 25, 2010 | 08:09 PM
RM_Indy's Avatar
RM_Indy
Id pass on it
Really need to get a donor truck to do it right.
Pull the puter, harness, mtr and trans.
Have to make mounts for the mtr & trans & cut the driveshaft.
Guy on another board did it recently.
Did a couple things to the 10 (rt cam, hdrs, tb) and seems to think it will run mid 12s na.
I figure him for 14 flat with it.
Havent seen him post in over a month since he got it on the road.
Old Jun 25, 2010 | 09:20 PM
RamSport97's Avatar
RamSport97
Originally Posted by RM_Indy
Id pass on it
Captain Cameltoe? He is a member on here too, just never logs on, I am with you on that, I don't think he is at mid 12s naturally aspirated as the newer SRT-10s are barely putting out low 13s stock.
Old Jun 25, 2010 | 11:16 PM
bigslick050's Avatar
bigslick050
It prob won't be worth it man. $500 is just the starting point of the wallet drain an engine swap will bring. Plus they only get 10-12 mpg. If your gonna swap an engine, look for a cummins switch, way more power potential, 20+ MPG, +BA
If you do swap for the 488ci, get the donor truck so can get all the parts ur gonna need easliy
Old Jun 25, 2010 | 11:40 PM
CPTAFW163's Avatar
CPTAFW163
I like the idea. He can post everything that goes wrong and we can find out how much it really costs.
GO FOR IT!!!
But seriously. It is not as simple as a pull and plop. YOu will need the computer and tranny. If the engine came out of a 4x4, then you will need to put in the transfer case as well...and the 4x4 axle. If you don't then the computer (which has wires running into it from the transfer case) will not work properly.
You see how much this is adding up already. You can BUY a v10 2500 for less than this will cost you.
Old Jun 26, 2010 | 12:29 AM
Bubba39047's Avatar
Bubba39047
well on the subject of engine swap, what about the v6 3.9l to a 318? i have the nv3500 tranny and it should bolt right up. how much would that involve?
Old Jun 26, 2010 | 09:23 PM
wow, i would have never thought id get this much help so quickly! im convinced. no engine swap for me hah
Old Jun 26, 2010 | 09:43 PM
rumble_truck's Avatar
rumble_truck
accept, there's alot more involved with a cummins, like spending 3k on a motor, run a 24v system, fuel lines etc.
Old Jun 26, 2010 | 10:02 PM
Yeah, for either project, it would actually be cheaper just to find a truck in the configuration you wanted.......
