Whats this called and?
Old Jun 25, 2010 | 08:10 PM
Skoubah's Avatar
Skoubah
Default Whats this called and?
Hello.
Can anyone tell me what the real name for this part is and where i can get a new one, i know i can at the junkyard but if i wanted to buy one bran new where and what is it called.
This is the second ram i had where this thing rotted out.
http://picasaweb.google.com/11221400...67502645027202
Old Jun 25, 2010 | 08:11 PM
RM_Indy's Avatar
RM_Indy
Quite simple, that part is called a "red x"
Old Jun 25, 2010 | 08:13 PM
Skoubah's Avatar
Skoubah
it wont embed, i had to link it.
Old Jun 25, 2010 | 08:16 PM
RM_Indy's Avatar
RM_Indy
Window weatherstriping
Old Jun 25, 2010 | 08:42 PM
Skoubah's Avatar
Skoubah
just as simple as i figured, but i have had people tell me what they "assumed" something was called before and then when i search it online i cant find it, so now i make sure to ask the experts
Old Jun 26, 2010 | 02:23 AM
dakotas ram's Avatar
dakotas ram
nice bronco,
http://www.lmctruck.com/icatalog/de/full.aspx?Page=9
in the right hand column, it looks like you need #6
duh Indy, its a seal, not stripping j/k
Old Jun 26, 2010 | 03:48 PM
94excoupe's Avatar
94excoupe
belt molding
Old Jul 11, 2010 | 10:34 AM
Skoubah's Avatar
Skoubah
Bump Bump
Need help as i am a newbie.
Ok so i got the part, however it does not come with instructions, adhesive or anything.
I dont know if it needs adhesive or not all i know is the one on my truck is tight as hell and i cant figure out whats gonna keep this new one in place.
It appears as though my mirror needs to come off the door, is that hard?
Once i do that how do i remove the old stripping?
Then how do i get the new stripping in place?
Im trying to do things myself but i just need a bit of help to get going.
Old Jul 11, 2010 | 10:56 AM
The belt molding is held in place by little 'teeth' in the part that slips over the lip on the door skin. They hang on pretty tight...... Start at one end, with a small screwdriver, and start prying it up. (go parallel to the molding, not perpendicular, dont wanna scratch the paint.) New one is simply aligned where it needs to go, and then tap it on place with the palm of your hand. (having the window rolled all the way down makes this exercise easier.)
If the mirror needs to come off, you will have to remove the interior door panel, and there are screws (bolts? something.....) on the inside. Careful with it though, the little plastic clips hang on to the door pretty tight, and will rip the slots out of the door panel before they let go of the door. There is a special tool for pulling them, that is rather handy to have..... there is another tool for removing window cranks if you have manual windows....
Old Jul 11, 2010 | 11:15 AM
Skoubah's Avatar
Skoubah
Ok issue then
The new one has no teeth.
I went outside with it and held it up to the door, it certainty looks the correct piece, but it doesn't have those these. I started to peel the other one off a bit just so i could see the teeth, yeah this one doesn't not have them.
I got this part from LMC, i know i ordered the right one, dont know if the sent me the right one, anyone have an issue with LMC sending out wrong parts?
The label on the part says door glass outer, left hand.
Which is what i need, i know sometimes after market parts change, maybe this is the new way they do it?
