E-Fan Kit Install
Old Jun 27, 2010 | 02:57 PM
CPTAFW163's Avatar
CPTAFW163
THe seller sells JUST THE SHROUD: $160
http://cgi.ebay.com/ebaymotors/Dodge...Q5fAccessories
you can put in any two fans you want that are 16 inches in diameter.
However, the fans and controller are pretty pricey when you buy them separately. HOWEVER, you can jsut get any TWO 16inch fans and wire them to run at 100% with a switch.
--Dan
Old Jun 27, 2010 | 02:59 PM
CPTAFW163's Avatar
CPTAFW163
Originally Posted by jasonw
If it was straight blades, perhaps. However, s-blades or curved blades are made to go in one direction, IIRC, and if you were to somehow reverse their spin, I doubt you'd get the right amount airflow. Someone correct me if I'm mistaken.
However, I believe the OP was referring to these.
The reserve bottle and the wiper bottle will have to be zip tied or otherwise attached near their original spots, if you can't fit the original fan shroud around those fans.
I would not buy that kit. they mount through the radiator and will puncture a tube.
Old Jun 27, 2010 | 03:02 PM
bigslick050's Avatar
bigslick050
Nice, all good info you guys. Will make sure to install the fans in the right direction...jasonw, you have the correct link to the item I purchased.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
I will keep you guys updated on this thread, and will post a simple DIY. The guy told me its about a one-two hour install. I will also be doing exstensive testing to show you all the results of this upgrade...should recieve it Tuesday.
Old Jun 27, 2010 | 03:12 PM
bigslick050
--Dan
Yeah that is true but if you go that route, it would be way more expensive (that shroud kit, fans, and control module/ wiring) plus purchasing all that separetly would be very inconvient whereas this kit has been tested by the seller and proven to work and supposedly comes with everything in box you need to get it running. Kit only costs 295 with shipping...if the MPG gain you get outta these is true, it will pay for itself over a long enough period of time. And they look really cool
Old Jun 27, 2010 | 03:56 PM
dodgeram07's Avatar
dodgeram07
i would ask the guy how many amps the fans pull,,,,, also thought thats a little high priced
(this was just a fast seach on ebay)
because
http://cgi.ebay.com/ebaymotors/PROCO...item35aa4d0c5e
and
http://cgi.ebay.com/ebaymotors/Flex-...item4cf013c68b
about a 110 dollars if you put it together you self
Old Jun 27, 2010 | 05:04 PM
ryan0714's Avatar
ryan0714
would runnin fans on 100% of the time cause any problems, power wise you think? i dunno how much they actually pull.
Old Jun 27, 2010 | 07:55 PM
Pacmanloads's Avatar
Pacmanloads
because
and
Says nothing about wires and relay kit.
Old Jun 27, 2010 | 07:56 PM
And why do the links tell me that the listing has been removed??
Old Jun 27, 2010 | 08:44 PM
Pacmanloads
I think I may get this kit as well and just fabricate a couple of simple brackets to mount them instead of going through the fins. I just asked the seller a question about a manual over ride switch to shut them off while crossing water and blast them when mudding and crawling . I will post his response and will probably order them tomorrow. 6000cfm should keep the old girl chilly .
Old Jun 27, 2010 | 08:47 PM
Pacmanloads
Low Drag Cyclone Blades w/ a 6000 Total CFM Rating
Low Amp Draw of 9 Amps Per Fan at Full Speed
Sealed Weatherproof Motors with Twin Ball Bearings
Lifetime Warranty
http://www.ffdynamics.com/ramB.html
