Old 08-13-2015, 05:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Blend door fix
Old 12-16-2010, 05:30 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,189 Likes on 2,942 Posts
Thank You Very Much. I am going to have to give that a shot, as currently, I don't hear the door slapping against the stops....... I suspicion I am going to have to go delving into my dash.......
  #22
Old 12-29-2010, 07:54 PM
tresvatos's Avatar
tresvatos
tresvatos is offline
Default for 96 Ram 1500?
well I guess I'm confused now!! I have the 1996 Ram 1500, but i ordered the heater treater part and have it here.. From reading these threads I take it the 96 Ram doesn't use an electric motor, but a cable, so I don't even need to use this part..?? I looked for the motor today and unless its covered in plastic, I don't see it... So does the 1996 have motor, or cable..? Thanks!
  #23
Old 12-30-2010, 07:41 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
96 has a cable, no electric motor.
  #24
Old 01-30-2011, 07:03 AM
JWACGB's Avatar
JWACGB
JWACGB is offline
Could someone tell me if the 97 1500 5.9l has the cable or electric motor? Me and my wife just bought this truck and the heat is not working correctly. I am gonna flush the heater core today to see if there is a blockage anywhere. Gonna change the thermostat Monday when i have a day off. Thanks for any help that you can provide.
  #25
Old 01-30-2011, 09:38 AM
HeyYou is offline
Look under the dash, passenger side, near the trans tunnel. If you have the electric actuator, you should be able to see it. Or, if it is cable operated, only thing you will see is the bottom of the blend door shaft sticking out an eight of an inch or so.
  #26
Old 01-30-2011, 09:48 AM
zman17's Avatar
zman17
zman17 is offline
It's a cable thru 98.
  #27
Old 02-04-2011, 12:23 AM
JWACGB's Avatar
JWACGB
JWACGB is offline
Default No heat
Well I have tried everything I know to try. Bought a flushing kit yesterday. Flushed the system. Seemed to have helped a little. Had a little better heat. So I figured that the radiator stop leak that who ever owned the truck before me had put in the radiator had stopped the heater core up. So I flushed the system with the flush kit that is suppose to remove all the gunk that builds up. Heat still isnt hot thought. Talked to a mechanic tonight that told me that if both heater hoses on the firewall are hot then it is not a heater core problem. That I should check the flap(sorry dont know what it is actually called) and see if its closing and opening. I have never done this kind of thing before so dont know what to expect yet. Probably gonna have to remove the whole dash just to replace parts if that is what the problem is. Cant seem to understand how a little flap could be causing all this problem though.
  #28
Old 02-04-2011, 09:44 AM
HeyYou is offline
Turn you temp control **** from one side to the other, you should hear the door thump shut at both extremes. (yours is cable operated by the way.) There is an adjustment procedure for it, that you can do from the drivers seat. Posted by zman, or j415. Do a search, should be able to come up with it.
  #29
Old 02-04-2011, 01:03 PM
Flipzslick's Avatar
Flipzslick
Flipzslick is offline
I tried To adj. My control on my 95 ram and my **** don't just pull out. It comes right off?
  #30
Old 02-04-2011, 03:36 PM
zman17's Avatar
zman17
zman17 is offline
The cable adjustment referred to is out of the 98 FSM. It's entirely possible that Dodge changed things through the years and is not an available option as a fix/adjustment on a 95.
Quick Reply: Blend door fix
