Old Aug 7, 2015, 01:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Diagnostics
Print Wikipost
Leaking oil
Old Jul 10, 2010 | 09:32 AM
dhvaughan's Avatar
dhvaughan
actually the rubber plug is on the rear diff.
your 4wd has a dana 44 front end. on the front side of the diff cover, about halfway up is a screw in, square head plug. unscrew this and fill the differential up until it runs out the hole.
you can use about any kind of gear oil, including 80w90, 85w90, 90w, or the expensive 75w140. it doesn't really matter what kind you use. what does matter is that you keep oil in it. to refill, put your finger over the spout and tilt the bottle up and above the steering rods, then shove the tip in the hole and squeeze. totatl capacity is about 2-1/2 quarts. you're probably not real low, maybe 1/2 quart.
you can tolerate leaking seals for as long as you wish, provided you keep it full of oil. if only one side is leaking, you can park overnight on a 2x8 to reduce the amount that leaks out.
Old Jul 10, 2010 | 09:40 AM
aim4squirrels's Avatar
aim4squirrels
Awe hell that's right. I'm the 2wd guy.
Old Jul 10, 2010 | 09:43 AM
dhvaughan's Avatar
dhvaughan
yeah - get a REAL truck !! lol, that way you have more **** to fix....
Old Jul 13, 2010 | 04:16 PM
barrypotts1b's Avatar
barrypotts1b
if i go off roading with the seal still leaking. Can that be a problem if it gets wet? will stuff get in there?
Old Jul 13, 2010 | 04:21 PM
aim4squirrels
It's actually easier to get your stuff in there when it's wet.
Old Jul 13, 2010 | 07:41 PM
kissmymagnum's Avatar
kissmymagnum
Hilarious stuff!!!!! Though I do fully agree!!
Old Jul 13, 2010 | 11:15 PM
dhvaughan's Avatar
dhvaughan
no, it won't hurt it. not unless you park overnight underwater.
just keep you oil level full.
Old Jul 13, 2010 | 11:23 PM
And if you DO go thru water deeper than your hubs, just have a look at the fluid later. If it is milky, or obviously contaminated, change it.
Old Jul 14, 2010 | 02:50 PM
DuranguenzeRam's Avatar
DuranguenzeRam
Ive had the same issue for two years. Every time i change my oil i have them refill fluid. Since the truck is barely driven only once has it needed a tiny amount of fluid. Also in the summer the seal with the heat will expand and leak more, ive driven in winter and the leak is minimal to none. you might also try parking with the wheel facing one way and see if leaks more or less vice versa.
