Timing chain help!!!
Old Jul 9, 2010 | 06:50 PM
SplatSTi's Avatar
SplatSTi
Old Jul 9, 2010 | 06:51 PM
SplatSTi's Avatar
SplatSTi
Originally Posted by truegent81
i understand how you feel atc...i have a cloyes chain going on soon..i have all my stuff for hughes, chain etc just sittin in the back of my truck. just havent had time, but the timing chain was my biggest worry...from what the haynes manual said, the top sprocket dot needs top point at 6oclock and the bottom sprocket needs to point at 12...
but from what ive heard you can just pull off the old chain and throw the new one on without doing any turning...the sprockets can only go on a certain way due to the keyways...i would do photobucket. easy to use and free.
i have a question for you though. 1) how did you remove the old chain set 2) what did you use to remove the fan system
i couldnt find a wrench big enough to bust the nut
Breaker bar?
Old Jul 9, 2010 | 06:53 PM
atc250r's Avatar
atc250r
Yup, splat, that's my pic. Thanks! Does it look ok everybody???
Old Jul 9, 2010 | 06:56 PM
truegent81's Avatar
truegent81
i dont see the marks on the gears but it looks good to me.
a breaker bar wont work. i need a open end wrench to remove the but bc the ****ing fan is in the way and there isnt much room. atc what did you use to remove the nut? open end wrench? what size? 1 1/4? or 36mm?
Old Jul 9, 2010 | 06:59 PM
aim4squirrels's Avatar
aim4squirrels
37-38mm monkey wrench, IIRC.
Old Jul 9, 2010 | 07:02 PM
atc250r's Avatar
atc250r
Can I just crank it over tomorrow without coolant and let it run for 5 seconds? If all sounds good I will fill it with coolant and be happy. If it sounds bad, is the damage instantaneous?
Old Jul 9, 2010 | 07:05 PM
aim4squirrels
That appears correct.
Assuming you didn't ever move the cam or crank sprocket without the chain attached, I'd say you're fine.
I would suggest running a tensioner with that particular chain, or you'll need to redo it within 50K more than likely.
Also appears that somebody used RTV instead of an oil pan gasket. If that hasn't leaked yet, lucky you!
You'll want to reapply a bit of new RTV on any exposed surface, but you really should have a gasket there.
Old Jul 9, 2010 | 07:20 PM
truegent81's Avatar
truegent81
new oil pan gasket is $35 from AZ (felpro) **** is expensive too...all the money and parts i have sitting in the back of my truck...sucks not having time...thanks aim for the input
Old Jul 9, 2010 | 08:37 PM
atc250r's Avatar
atc250r
Well, I will fire it up tomorrow and pray that it's ok. Would it do instant damage if its wrong?
The rtv that is on top of the oil pan gasket is a micro-thin layer. I put some fresh rtv there as well so I can't see it leaking.
Old Jul 9, 2010 | 08:45 PM
aim4squirrels
The camshaft and crankshaft being incorrectly aligned can cause immediate and utter engine failure, yes. A very tiny amount of movement most likely would not. Move the cam 10, 20, 30, degrees out of alignment and you could be purchasing a new engine.
Best way to check is to turn the motor over by hand with no spark plugs in and see if the crankshaft makes it 2 complete rotations. If it does, you are probably safe. Do this by reinserting the crank bolt and turn it around 2 full turns with the socket.
If it stops or catches anywhere along the way, the piston and valve has collided somewhere and you will have to re-degree the camshaft in relation to the crankshaft.
