The night before the gears go in... UPDATED
on
1 Post
https://dodgeforum.com/forum/2nd-gen...showed-up.html
I ****ed up a bit when ordering I forget to ask for a rear yukon but oh well.
I have been looking over that gear in period thing you posted, is it really nessary to stop and let them cool down like that? It would take me about 2hrs to get home.
I know tomorrow on the way home I'll be in stop and go traffic.
Hammers right, don't take any whine. If she whines go back immediately and slowly. Be sure t check 4wd too!
It's more heat than distance you're worried about when breaking them in. Stop and go won't do much to build heat as the Diff won't be working really hard.
Make sure you heat cycle the front set at some point as well.
If you aren't in four wheel drive, the ring and pinion in front aren't turning. Not to mention there is no load on them in any event. Need to find some gravel parking lot, or a nice straight stretch of road, and engage the 4x4, and see what it sounds like. Keep in mind, you need to break in the front gears, and that can ONLY be done in four wheel drive.
I drove about two tanks worth with the open locker in the front and was careful about turning and parking, so forth. My front oil looked especially bad when I did change it, so it is worth doing right.
Most Richmond gears have that issue. Yukons are usually Richmond rebranded, but the shot peening Yukon does typically gets rid of that whine.
There's only a few companies that actually make gears and everyone else rebrands them. Some don't do a damn thing to them except repackage and markup the price.
I one set I've been warned against repeatedly is Genuine gears, every shop I called warned me about them (except 4wheelparts as they sell them). One guy even told me they should rename the company Gen U whine.
on
I've had Genuine's in my truck for almost five years now, never had a hint of whine. They are actually re-branded Auburns or at least were back when I got mine, I confirmed this with an Auburn rep at a truck show. I went with them because of the Lifetime Warranty.
I think the reason why Genuine's got such a bad rap is that they are primarily sold by 4 Wheel Parts and the typical 4 Wheel Parts store doesn't pay well. As a result they have a bunch of sorry a$$ installers. I know a guy who is a mechanic at my local Dodge dealership who worked at a 4 Wheel Parts right after high school as a "tech" for all of $9 an hour. He's got some real horror stories about the sh*tty work turned out by lousy techs at 4 Wheel Parts in Orlando!!!
Now my local 4x4 shop sells Genuines and I've sent about half a dozen guys there for gears, two members of this forum included and none have had a hint of whine.
Yeah you can get a bad set once in a while from ANY manufacturer, but with gears IT'S ALL ABOUT THE INSTALL!!!
It's funny how a component can get a bad rap in no time anymore though. I had NEVER read a bad thing about Motive Gears ever and we had a kid in 3rd Gen go through two sets that supposedly howled like hell. Got the first set swapped out by Motive, no questions asked. Second set howled and the installer had the kid buy a set of Yukons finally stating "I've never had a set of Motive's that worked". The Yukons didn't make a hint of a sound. Kid got his $ back from Motive, again with no difficulty. Was it the gears or did the installer just get lucky on the third install? I dunno, but I know probably two dozen guys running Motives without issue.
But the kid got on here and a couple other forums and really bashed Motive. Now I have read how they are NO GOOD on about every forum recently. Most of them linked to posts made from the kid from here that he either made on DF or another forum...
