engine swap question
Old Jul 19, 2010 | 07:19 PM
97ram5.2's Avatar
97ram5.2
well hopefully it holds up im running a 4.5 suspension lift with a 3in body and 37s and i beat the hell out of it and she shifts real smooth still so hopefully the 5.9 dosnt trash it
Old Jul 23, 2010 | 08:56 PM
97ram5.2's Avatar
97ram5.2
going to do the swap hopefully sunday will the motor run with the 01 pcm i no it will throw dash lights on but untill i get my pcm i wanna see if it runs also can i swap intakes with out changing nething else, and im replacing the clutch pressure plate and flywheel should i get an 01 or 96 clutch setup ......also i looked at the door tag and its an 00 not sure if that changes anything thnks all...
Old Jul 23, 2010 | 10:20 PM
It might. Don't expect any of your dash gauges to work though..... Would be best to have the right PCM in there... don't wanna let any magic smoke out.
Old Jul 24, 2010 | 05:37 PM
97ram5.2's Avatar
97ram5.2
yea i better just get a pcm hopefully the junkyard has one.... anyones input on the intakes if there direct swap
Old Jul 24, 2010 | 06:11 PM
97ram5.2's Avatar
97ram5.2
also would a 96 360 auto computer work would just throw codes for not reading the auto tranny sensors right
Old Jul 24, 2010 | 06:51 PM
dhvaughan's Avatar
dhvaughan
i don't really know, but the 96 pcm might be very forgiving of the auto/manual trans swap. somewhere in there was the changeover from transmission 46RH to RE. the RE has the electronics and the RH i think has none except maybe a temp sensor. i think it'll either work or not, and if it doesn't, i don't think any damage will occur. just my shade tree opinion.
Old Jul 24, 2010 | 06:54 PM
dhvaughan's Avatar
dhvaughan
intake is a direct swap. use your 96 temp sensors.
Old Jul 27, 2010 | 07:57 PM
97ram5.2's Avatar
97ram5.2
alright pulling the motor tomorrow but i got 2 dumb questions can i use the wireing harness that on the 360 out of the parts truck or do i have to use the 318 wiring harness? and do i want a clutch kit for a 360 or 318? and for what year or r they all the same?..... thanks alot guys
Old Jul 28, 2010 | 01:17 PM
mrfarrell's Avatar
mrfarrell
use the wiring from the 318 and the clutch is the same between the both of them just make sure you get a 360 flywheel
Old Jul 28, 2010 | 06:16 PM
97ram5.2's Avatar
97ram5.2
alright will do thanks just curious whats diff between the 318 and 360 flywheel but not the clutch and what year should i get it for 96 or 01? the 318 wireing harness will plug right into the 360 injectors? im just wondering so i no for the future in case im ever asked this question whats the diff between the 360 and 318 wireing harness b sides the temp sensors? does it not plug into the 96 360 pcm thanks guys il b out of your hair with dumb questions hopefully after this weekend..
