lockin out hub conversion?
I am having a hard time coming up with anything for the 1500's... but, the D60 kits run close to 2 thousand dollars...... Seems some folks have had success with just scavenging the whole front axle out of a Ford truck...... all the mounts were pretty much the same. Granted, that was out of a 3/4 ton truck, so, D60 as well. I don' know what ford used in their half-tons, and if all the mounts were the same.
Quite frankly, that is a crapload of money, for what you are getting. I would be real tempted to wander the junkyards, and find a D44 that has all the stuff you are looking for, and see if it would all change over. I wouldn't think there would be THAT much difference. Could always separate them at the balljoints, take take everything outboard from there. (including the outer axle stub)
yep its really saves on the u-joints and axle seals.. http://www.emsoffroad.com/store/inde...roducts_id=262
Neat trick. And not nearly so pricey, but, still pretty steep. Not a whole lot more than having to replace the hub/bearing assemblies though...
Trending Topics
Unfortunately, using older ford/chevy 44 parts does not work due to the knuckles being completely different (ball joint locations are not the same). I have seen guys fab up a lockout kit on a 60 from old axle parts, but on a 44 I am pretty sure it is not possible.
