vibration at 75mph
Old Jul 14, 2010 | 07:37 PM
popowiecki's Avatar
popowiecki
Default vibration at 75mph
lets start of by saying i replaced the panard bar, sway bar end links and bushings, and inner tie rod outer tie rod drag link and steering shock. tires are also rotated and ballanced also front end alignment was just done. but at 75 mph i hear and feel a vibration in the gas pedal and the steering wheel. it vibrates and grinds kinda sounding? any ideas? thanks for any suggestions
Old Jul 14, 2010 | 07:39 PM
Check your wheel bearings, and ball joints. Sounds like you have everything else covered.... any slop in your steering?
Old Jul 14, 2010 | 09:14 PM
Jason1980's Avatar
Jason1980
I got the same problem with my truck. I replaced all of that and on the passnger side I noticed that my brake pad on that side was right down to the metal no pad left and that helped alot but. I still feel it a little bit... and I got just a little slop in the steering... an ideas????
Old Jul 14, 2010 | 10:06 PM
Please start your own thread, detail the problem, and what all you have done. There are so many different possible causes, and trying to troubleshoot two vehicles in the same thread is a bit confusing.
Old Jul 14, 2010 | 10:11 PM
dhvaughan's Avatar
dhvaughan
vibration - usually a bad balance. sometimes a shop's balance machine is out of whack. have them recheck. if you don't trust them, take it somewhere else and have them checked/rebalanced.
Old Jul 15, 2010 | 07:26 AM
popowiecki's Avatar
popowiecki
I was wondering if it could be in the shaft that goes from the steering wheel to the gear box does that ever go bad and how do you tell. my wheel bearings and ball joints were replaced in 06. I will look at them tonight when i get home from work. thanks for the replies if anymore ideas are out there for me to look at it would be great
Old Jul 15, 2010 | 07:37 AM
dhvaughan's Avatar
dhvaughan
i doubt it. the steering shaft does wear out, which creates some back and forth play, some clunking, loose feel, etc. but - the shaft only rotates a little when steering, which your not doing much of at 75mph LOL.
vibration at speed will be coming from something thats turning - tire, wheel, bearing, axle and u-joint (4wd).
are you 2wd or 4wd. if 4wd and its not tires, check axle u-joints which turn full time.
Old Jul 15, 2010 | 11:23 AM
JohnnyZJ's Avatar
JohnnyZJ
wheel bearings vibe when then go, and grind as well. easy way to determine. jack up one side of truck, give the tire a good shake. there should be ZERO movement. if it moves, unit bearing is gone. could also be ball joints though.
what kind of tires are you running? are they old walmart type tires?
crap tires have a tendency to split belts on the inside of the tire that will go un noticed on a tire balancer. i know this because its happened to me.
jack up the truck, figure out if theres movement in your front end. if not, throw on a set of 'known to be good tires' and take it for a spin.
Old Jul 15, 2010 | 11:51 AM
brettj2408's Avatar
brettj2408
what truck is this?
if its a 4wd do you get clunking when turning?
try putting it in 4 wd and see if it gets worse
check your wheel bearing by lifting the front end up and shaking the tire at 3 and 9 o clock and also 12 and 6 o clock for any movement.
Old Jul 15, 2010 | 04:49 PM
popowiecki's Avatar
popowiecki
the truck is a 00 2500 sport 4x4 quad cab. Tires are goodyear mud terrain old style. no cupping or wierd thing tires are in good shapei jacked up the tires no movement at all up and down or side to side. does the front drive shaft spin if the truck is in two wheel drive, also can i take it off to see if its one of them u joints or if its the rear u joint. ill have to take that apart next and move them around to see if any play in them
