I give up
Old Jul 19, 2010 | 07:40 PM
  #21
98BlueSport's Avatar
98BlueSport
are we talking about the thing that looks like a valve steam? on the drivers side fuel rail?
Old Jul 19, 2010 | 07:41 PM
  #22
That would be the feller. You have one??
Old Jul 21, 2010 | 08:21 PM
  #23
98BlueSport
yup its on there. I replaced the TPS last night, and that deff made a difference in how soon the truck kicks down and moves.
the 35s and 3.55 gears dont affect anything at all. It isnt a race truck, i havent felt a loss in power or even in fuel mileage
there is no cam in the truck it was a reference.
Old Sep 6, 2010 | 08:06 PM
  #24
jetrbl's Avatar
jetrbl
Did you ever find the problem. I'm having the same issues.
Old Sep 6, 2010 | 08:26 PM
  #25
CPTAFW163's Avatar
CPTAFW163
if it smokes like a diesel, you have blow by. Prev owner must have ran it hot multiple times.
Old Sep 6, 2010 | 09:22 PM
  #26
UnregisteredUser's Avatar
UnregisteredUser
I'm with J McWillis on the MAP sensor, but there's no way to tell for sure from this far away. Another option is an undetected vacuum leak.
Old Sep 6, 2010 | 09:40 PM
  #27
drewactual's Avatar
drewactual
dude- the very first thing I would do is 'borrow' a set of 17" rims and rubber from a buddy or something, and go pick out something heavy to tow..
I have a similar set-up, but I'm going to 4.56's by the end of the week.. I pull a lousy 2k# every single weekend, and there is a huge difference between 33" stock and 35" cepeks.. just sayin' man..
Old Sep 6, 2010 | 10:37 PM
  #28
hydrashocker's Avatar
hydrashocker
Currently has 35s on it with the 3.55 gears, and i haven't had a problem till i hooked up, but i know its now because of the tires because it did this before with the tiny 265s.
It stumbles its way to 3000 because the pcm is dumping so much gas into the motor, if i stand in it, it smokes like a diesel
Simple fix,
Replace the pre-CAT 02 and get some gears. Turning that with oversize and 3.55 ratio well there's your issue not to mention a bad 02. Replace with a Dealership 02 and call it a day.
Old Sep 7, 2010 | 01:21 AM
  #29
jasonw's Avatar
jasonw
Site Moderator
I have one on my 2001.
I agree with the rest. Your gears + tires may be part of the problem, but there is something else going on. The pre-cat O2 sensor, or one of the other sensors that contributes to the air/fuel ratio.
You don't necessarily need a dealership O2 sensor... if you can find one, NTK/NGK makes a nice sensor.
Old Oct 20, 2010 | 03:20 PM
  #30
Road Hammer's Avatar
Road Hammer
Ok, I'm just gonna throw this out there and you guys chew it up! LOL
I had experience with a GM truck that ONLY lost power when it pulled his boat trailer, we went all through that damn truck on numerous occasions. Then we found it...by fluke! The problem? The truck had a 1 7/8" ball and the trailer had a 2" coupler, the trailer coupler would move/bang (not loudly at all) back and forth on the smaller ball, the engine anti-knock sensor would pick it up as engine pre-ignition and keep retarding the ignition timing until the truck would barely run! I'm new here and have no idea if our trucks have anything similar or not, but like I said, I just thought I would throw it out there!
Good luck!
