check engine light flashing under load. cylinder #5 misfire
Old Jan 27, 2012 | 09:09 AM
  #31
Augiedoggy's Avatar
Augiedoggy
Originally Posted by zman17
I assume you've also replaced the crank and cam sensors to no avail?
I have not...I asked my mechanic about it and he seemed to think because the #1 plug is the only one that looked odd and that at the time I was getting no codes that it was something else... how difficult are they to access... the issue started when my tranny was rebuilt so I thought maybe the sensor could have gotten damaged or knocked around... Isnt one in the distributor and on on the block by the tail-housing?
I still have the noises at the head which seems to quiet down after warm up?
Old Jan 27, 2012 | 10:02 AM
  #32
Crank sensor is on the back of the block, passenger side. It is frequently a victim of tranny swaps...... cam sensor is in the dist. Not in quite as much danger of being damaged during a swap.
Old Jan 27, 2012 | 10:17 AM
  #33
Augiedoggy's Avatar
Augiedoggy
I will check them out, thanks guys...
Old Jan 29, 2012 | 11:48 AM
  #34
AKZEP69's Avatar
AKZEP69
fyi it is 15 deg below zero - right now & has been like this since early nov.
i feel the cold has caused the cat to be issue with my 01 360 off-road - ? is what's an easy fix ?
ideas appreciated!
thx
Old Jan 29, 2012 | 11:56 AM
  #35
zman17's Avatar
zman17
Retired Moderator - RIP
The cold is not going to effect the cat. I'd say you have other issue(s). And since you have not stated the problem you are having, I don't think anyone wants to guess.
Old Jan 29, 2012 | 11:59 AM
  #36
Augiedoggy's Avatar
Augiedoggy
ideas appreciated!
thx
I agree we dont know what you issue is of if you have codes? have you ruled out the 02 sensor? If you feel your cat is clogged I've seen a trick is to put about a gallon of laquer thinner in the fueltank with a half a tank of gas and run the engine at 2,000 rpm for a half hour to clean it out.... I saw it on youtube... some actually remove the cat and wash it in solvents too....(or replace it . they can be found new for as little as $68 bucks on ebay)....
Old Jan 29, 2012 | 12:02 PM
  #37
Augiedoggy's Avatar
Augiedoggy
theoretically extreme cold will effect it.... It supposed to reach a certain very high temp to do its job...at -15 it may not be getting hot enough , especially if the plenum is shot and the trucks burning oil from that or just being worn out...
Old Jan 29, 2012 | 12:05 PM
  #38
zman17's Avatar
zman17
Not to mention you can gut it.(illegal) But cheap. And if it is clogged there is a reason why. https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Jan 29, 2012 | 12:07 PM
  #39
zman17's Avatar
zman17
Well if it's clogged or clogging, it's getting plenty hot enough. That's why they glow when clogged.
Old Mar 25, 2012 | 08:26 PM
  #40
bigyeller's Avatar
bigyeller
mine is doing the same on #7. check fuel pressure cylinder compression, changed plugs wires cap and rotor. everything checked out ok. and it still does it. i even checked the injectors and pigtails. they were fine too. could it be timing or bad valve spring
