check engine light flashing under load. cylinder #5 misfire
Old Aug 24, 2012 | 09:55 AM
  #71
aofarrell2's Avatar
aofarrell2
Well if he has had plenum troubles and/or cracked head those valves won't be sealing anymore. Pull the most troublesome head, have it magnafluxed, and then do a valve job if it is okay.
Old Aug 24, 2012 | 10:44 AM
  #72
It's Me Patt's Avatar
It's Me Patt
did have the 'dodge' plenum issue and I'm confident the seat is cracked, seems to be another common theme with our CH's. I have a budd on here that has an extra head so I'm looking in that direction...
Old Aug 24, 2012 | 10:45 AM
  #73
Might just want to spend the coin for a better than factory replacement. Odessa sells a pair of better heads for under 600.00.... on ebay.
