check engine light flashing under load. cylinder #5 misfire
Old Aug 22, 2012 | 03:09 PM
  #61
aofarrell2's Avatar
aofarrell2
Run your gas tank till it is less then 1/8 full then put 10 oz. of chevron techron fuel system cleaner, the more powerful stuff, I think it is in the 20 oz bottle. That will clean some carbon and other residues, might help with misfire for awhile. Did that on our truck, worked really nice for a bleeding edge solution.
Old Aug 22, 2012 | 04:44 PM
  #62
It's Me Patt's Avatar
It's Me Patt
Did that and seafoam too via the bb vac..th CEL hasn't come on for some time now..getting things narrowed down tho...thanks K
Old Aug 22, 2012 | 06:42 PM
  #63
aofarrell2's Avatar
aofarrell2
No problem.
Old Aug 23, 2012 | 10:28 AM
  #64
It's Me Patt
CEL is back on
Old Aug 23, 2012 | 10:34 AM
  #65
aofarrell2's Avatar
aofarrell2
What is the DTC it is giving you? Also, have you routed the ignition cables per TSB 18-48-98 http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm ? If you didn't it might help you.
Old Aug 23, 2012 | 07:19 PM
  #66
It's Me Patt
Yeah, I checked, rechecked and checked again..I'm only pulling 130 on that cylinder so I think that's the cause
Old Aug 23, 2012 | 07:39 PM
  #67
aofarrell2's Avatar
aofarrell2
What are the adjacent cylinders giving you? Just wondering...
Old Aug 24, 2012 | 09:04 AM
  #68
It's Me Patt
dry:
#8-130-135
#6-178-180
#4-178-170
#2-160-170
wet:
#8-130-135-130
Old Aug 24, 2012 | 09:06 AM
  #69
Valve trouble.... can try running seafoam thru it, and see if that doesn't help some.
Old Aug 24, 2012 | 09:44 AM
  #70
It's Me Patt
I've gone through two cans over the past two weeks..through the bb, gas and oil..most through the vac line tho and not a drop of smoke..
