best exhaust and CAI for towing
Old Jul 25, 2010 | 12:27 AM
SKOALRING96's Avatar
SKOALRING96
Default best exhaust and CAI for towing
im sure this question has been beaten to death already but ill ask it again. What is the best exhaust system for towing power. rite now my truck is straight piped and will not pass emissions. i regularly tow between 5200 and 7000lbs. i was kinda disapointed with my trucks towing performance with the stock exhuast system and it was yet worse with after straight piping it. ive heard rumors that aftermarket exhaust systems and CAI actually make towing performance decrease. so is the stock intake and exhuast really the best for towing and if not what do you guys recomend
Old Jul 25, 2010 | 12:36 AM
lastrights's Avatar
lastrights
i highly reccomend a higlflow cat with some kinda muffler and you should be mpore than good enough, you can also buy a 14x3 round intake from advance or pep boys.
also you may want to check your truck for a failure of the plenum,look down your throttle body for oil. and throttle body spacers are junk if thats the spacer your relating to in your sig
Old Jul 25, 2010 | 12:54 AM
SKOALRING96
lastrights - do the throttle body spacers actually cause a "drop" in power or does it really have no affect?
Old Jul 25, 2010 | 01:00 AM
lastrights's Avatar
lastrights
when i 1st bought my truck , it was the 1st mod i did and then came on here and guys said it does nothing that its just a paperweight, and i took it off and i felt a gain in low end .
there a big read on here somewhere about it and why it does nothing , someone actaully did a dyno run with it and showed a loss in hp/tq
Old Jul 25, 2010 | 01:18 AM
SKOALRING96
hmm, learned somethin new, i definatly gotta do my plenum ive been putting it off for too long now. im not sure how long the plenums been leaking but could that lead to a loss in engine power?
Old Jul 25, 2010 | 01:22 AM
lastrights's Avatar
lastrights
ya huge loss in power , leaking plenum can also clog cats ,and clog o2 sensors and prob will need new plugs also
Old Jul 25, 2010 | 01:28 AM
SKOALRING96
alright ill prbly do the plenum, intake gaskets, valve cover gaskets, head gaskets, sensors and plugs all at once then, thanks for steering me in the right direction lastrights....kinda steered away from my original question but at least i now know why i had no power
Old Jul 25, 2010 | 01:36 AM
lastrights's Avatar
lastrights
ya no problem, if your looking for the 1st mod . do a tuner either superchips or sct .. these motors are really detuned form the factory and wake up with a tuner day and night diffrence
theres step by step guides and parts list on here on how to do the plenum. and tune up is easy also
also this is a good place to be for there is how to do , and arage of polls to what people do with there truck and likes and dislike of the mod,oils,gears,shock ext . https://dodgeforum.com/forum/2nd-gen-ram-faqs-143/
you prob dont have to do your head gaskets unless there leaking
you could also do a fastman for throttle responce or make your own if you have access to a milling mashine to remove the walls on the throttle body from blocking air to go into the intake manifold. fastman bores out the throttle body , but just taking off the walls would help for a cheaper route Name:  wm_normal_255837.jpg
Old Jul 25, 2010 | 02:05 AM
SKOALRING96
Alrite my first priority is gonna be the plenum now but does the combo of a magnaflow high flow cat along with a split side flowmaster cat back sytem (50 series muffler) sound good for towing I would just let it go the way it is but Id like to make more power and I definatly want it to be heard
Old Jul 25, 2010 | 02:09 AM
redheadhunter21's Avatar
redheadhunter21
Good exhaust for towing starts with a smaller pipe so a 2.25 inch pipe over a 2.5 and 3 is a start, and then a CAI will help with upper end without losing low end, not much of a difference really between brands
