is the brake booster causing this noise??
Old Jul 28, 2010 | 09:33 PM
  #21
JRob238's Avatar
JRob238
Thats right I forgot you said it was already making the noise before the gear. Man I really dont know. Sorry I wasn't of more help. I am gonna go out tomorrow and take a look around underneath my dash and at the firewall of the engine compartment to see if anything rings a bell to me. I am curious now to what is causing this.
Old Jul 28, 2010 | 09:36 PM
  #22
JRob238's Avatar
JRob238
hey have you ever disconnected your front sway bars? this is a shot in the dark but my friend had a similar noise on a jeep and it turned out to be a loose washer. lol like I said shot in the dark but im just trying to brainstorm every piece that could possibly spin and make that sound and be in the general area of where the sound seems to be coming from.
Old Jul 28, 2010 | 09:48 PM
  #23
townsley4's Avatar
townsley4
its alright, you would almost have to hear the noise, its hard to explain. ill try a dif camera some time and see if i cant pick it up. but ill take a look at the sway bars. ive tried to brainstorm everything i could think of but its hard because the sound can only really be heard in the cab, not outside the truck. and its def coming from somewhere in the front in the dash or infront of the dash.
Old Jul 28, 2010 | 09:55 PM
  #24
JRob238's Avatar
JRob238
Ok like I said I will take a look at mine tomorrow. Im gonna be under there anyway testing the plenum and fixing my cig lighter and power outlet
Old Jul 28, 2010 | 10:16 PM
  #25
townsley4's Avatar
townsley4
how you goin to test the plenum?
Old Jul 29, 2010 | 06:55 PM
  #26
townsley4's Avatar
townsley4
well i uploaded one video to photobucket, here is the link i wasnt sure how to upoad directly to this post.
but its hard to hear but u can hear it. have to turn the volume on ur speaker sup pretty high, and u can hear it best at around 15-25 secs into the vid. its a faint grinding churning noise. let me know if u can hear it, if not i will try to get a better vid.
http://s1024.photobucket.com/albums/...t=VID00098.mp4
Old Jul 30, 2010 | 08:54 AM
  #27
krs7272's Avatar
krs7272
I had the same thing and have it again now. It's the control arm bushings. Grease them and it will go away.
Old Jul 30, 2010 | 01:31 PM
  #28
townsley4's Avatar
townsley4
you would think if it was you would be able to hear it outside the cab?, and i crawled under there and looked but how are you supposed to grease them? mine dont have grease nipples, and i found out the grease nipple on my right upper ball joint is broke off
Old Jul 30, 2010 | 01:37 PM
  #29
FarmBoy428's Avatar
FarmBoy428
Hey Ryan, wat was that site i was supposed to loook up for you. I forgot about doin that.
Old Jul 30, 2010 | 11:00 PM
  #30
krs7272's Avatar
krs7272
You have to remove the trailing arms to grease. PITA but it's what needs to be done.
