is the brake booster causing this noise??
Old Jul 31, 2010 | 01:02 AM
  #31
townsley4's Avatar
townsley4
yea, might as well buy and install some with grease zerts? and i found out that my upper ball joint grease zert insert is stripped out while i was at it. i found some in the garage but they wouldnt tighten, and im sure it is threaded because the other side is threaded. and i will try to grease the contral arm bushings sometimes this weekend and see if that makes the noise dissapear? did yours make the same noise mine is? and thanks for the info i will give it a shot.
farmboy, not sure what u weregoin to look up man lol
