ABS light on only ... Truck stuck in 1st gear !
What year is your truck? You may have a speed sensor on the tranny also that could be shot.
I experienced the same issues once with my 2nd gen, even after I replaced the rear speed sensor. I then realized the wires were worn through where they are attached at the frame rail (above the rear axle). Spliced them back together and walla!
Boy, I sure feel like a dink. Yeah, I think that is when they quit putting the sensors there... or even in '98.
Thanks for all your post Guys !
I finally resolve my problem today !!!!
1. Un-plug the ABS module
2. Clean both connector with an electronic cleaner spray
3. Re-plug !
Not even 5 mins ... No more ABS light on the dash !!! Truck Running perfectly !!!
3. Re-plug !
I believe all 2nd gens do. But, some time around '98 or so they quit putting one in the tranny also.
Yep, thats my excuse!
And Kevin, glad to hear that you got er fixed!
