electric fan conversion
Old Nov 6, 2010 | 09:12 AM
  #21
gipperkid's Avatar
gipperkid
Originally Posted by BlueBeast2
Got everything from Summit
PRO-67016 FAN ELECTRIC 16" UNIVERSAL 65.95
PRO-67014 PROFORM 14" FAN 65.95
SUM-890014 DUAL FAN RELAY 69.95
I see some people running 2 16" fans but 2 16's wouldn't fit on mine. I had to do a 16 and a 14.
You'll have to wire up an additional relay for the ac or figure another way to make them kick on with you turn it on. The summit relay kit the temp sensor is in the coolant which is better then the ones you just shove in the rad fins
Where did you install the coolant sensor at?
Old Nov 6, 2010 | 12:32 PM
  #22
dodgedude37's Avatar
dodgedude37
Default pics of fan install
Well here they are, at the highest setting on the thermostate, I am running about 10 degrees cooler. The aluminium shroud adds to the cooling for extreme areas. And in pic 3 look how much room you have to work on the engine.
Attached Thumbnails electric fan conversion-01-dodge-fan-conversion-002.jpg   electric fan conversion-01-dodge-fan-conversion-003.jpg   electric fan conversion-01-dodge-fan-conversion-005.jpg   electric fan conversion-01-dodge-fan-conversion-004.jpg
Old Nov 6, 2010 | 12:34 PM
  #23
dodgedude37
gripperkid
The sensor goes through the radiator as close as possible to the top rad. hose
Old Nov 6, 2010 | 12:37 PM
  #24
J415's Avatar
J415
Anyone interested in doing this mode, PM me. I have a dual speed/ hi low e fan for sale. I was gonna do it but cash is tight right now.
Old Nov 6, 2010 | 12:59 PM
  #25
gipperkid's Avatar
gipperkid
Originally Posted by dodgedude37
gripperkid
I was talking about the thread-in sensor that comes with the Summit dual fan kit. I think a better reading comes from the sensor that is in contact with actual coolant rather than one of those probe style sensors.
Old Nov 6, 2010 | 01:01 PM
  #26
gipperkid's Avatar
gipperkid
Did the kit come with the aluminum plates or did you make them?
Old Nov 7, 2010 | 12:20 PM
  #27
dodgedude37
the aluminium parts are not plates they are shrouds & they come with the fans ready to go.
Old Nov 7, 2010 | 12:58 PM
  #28
slider15004x4's Avatar
slider15004x4
It looks good dodgedude. Is this the Ultra extreme kit?
Old Nov 7, 2010 | 02:01 PM
  #29
aim4squirrels's Avatar
aim4squirrels
Doesn't matter where the reading comes from, it's where you set the fans to go on and off.
The probe is a much easier setup than the screw-in type sensor and you don't ever have to worry about a leak. If the temp of the coolant goes to high, you adjust the fans to come on earlier.
Mine pop one about 10* after the 180* t-stat pops open. That way, they don't run while I'm driving down the road and the ram air from 45mph+ cools the rad just fine. If it's really hot out they assist, and if I'm in stop and go traffic, they take the brunt of the heat removal. If I was at the track, I'd probably notch them down a bit to compensate for severe strain I'm putting on them.
Old Nov 9, 2010 | 06:55 PM
  #30
dodgedude37
slider15004x4
yes, custom utra extreme
dodgedude
