How to tell which gears I have...
Old Jul 31, 2010 | 08:14 PM
mjonesjr's Avatar
mjonesjr
Default How to tell which gears I have...
How do I tell which gears I have in my truck? I would like to find out so I can possibly go to a slightly lower gear.
Old Jul 31, 2010 | 08:21 PM
Check the tag on the axle. If that isn't there, request a build sheet from chrysler, instructions to get one in the FAQ section. If you are impatient, jack up the rear of your truck, put it in neutral, block one tire, turn the other one half turn, and count the number of driveshaft revolutions. That's your gear ratio.
Old Aug 2, 2010 | 09:16 PM
kissmymagnum's Avatar
kissmymagnum
If your truck hasn't been messed with, you should also have build data on a label on the underside of the hood near the grille bracket. Mine still has it, but I know that some don't have the same convenience.
Old Aug 2, 2010 | 09:28 PM
mjonesjr's Avatar
mjonesjr
Mine has it, but it is faded to where you can't make out any of the printed text.
Old Aug 2, 2010 | 09:31 PM
Maxx_Magnum's Avatar
Maxx_Magnum
tell us more about the truck, year, 1500/2500, engine... it'll help us determine what ya got
Old Aug 2, 2010 | 09:34 PM
mjonesjr's Avatar
mjonesjr
See Signature
Old Aug 2, 2010 | 09:37 PM
Maxx_Magnum
I would guess that you have 3.55 gears if I had to... thats the most common for the 1500s
Old Aug 2, 2010 | 10:43 PM
dodgeman52's Avatar
dodgeman52
or maybe 3.92 but i doubt it would have it
Old Aug 2, 2010 | 11:15 PM
aim4squirrels's Avatar
aim4squirrels
mine had a sticker in the glove box.
You could jack up the rear end, put it in neutral, mark the tire and drive shaft with chalk and spin the tire. Count how many times the drive shaft turns for each one rotation of the wheel. 3 1/2 turns is 3.55 gears, almost 4 is 3.92, just over 4 is 4.10, etc.
Old Aug 3, 2010 | 12:30 AM
FarmBoy428's Avatar
FarmBoy428
that wouldn't be a bad idear, but wouldn't it take a while to figure it out lol.
