4x4 wont work
Old Aug 3, 2010 | 10:17 PM
dhvaughan's Avatar
dhvaughan
follow the vac line from the intake manifold down to the top of the t-case, where there is a switch. from there follow 2 lines to the cad.
....or just buy a posi-lok and be done with it.
Old Aug 3, 2010 | 10:54 PM
lifted99ram1500's Avatar
lifted99ram1500
What is a posi lok?
Old Aug 3, 2010 | 10:58 PM
Test for vacuum at the switch. Just put the supply line on there, and have a friend switch into 4wd. see if the vacuum switches ports, and how strong it is.
Old Aug 4, 2010 | 03:22 AM
Gnarkill666's Avatar
Gnarkill666
Here is a really good place to look, find the lines that run on the inside of the frame and where it is about 2 inches or so from the passenger side exhaust manifold and for some stupid *** reason has a factory bend AWAY from the frame that actually puts it closer to the exhaust. no joke i had a problem where i couldnt get the front hubs to disengage hardly because that line was completely melted, being aluminum. you might have the other line on yours with a hole melted in it there.
Old Aug 4, 2010 | 10:23 AM
JohnnyZJ's Avatar
JohnnyZJ
Originally Posted by lifted99ram1500
What is a posi lok?
google is your friend on this. google Central Axle disconnect, grab a coffee and start reading you will answer your own questions!
Old Aug 4, 2010 | 09:12 PM
dhvaughan's Avatar
dhvaughan
What is a posi lok?
its what you install after you get tired of screwing around with that stupid cad.
https://dodgeforum.com/forum/2nd-gen...installed.html
