4x4 wont work
Old Aug 3, 2010 | 04:54 PM
lifted99ram1500's Avatar
lifted99ram1500
Default 4x4 wont work
hi my 99 dodge 4wd does not work i will put it in 4x4 and the front drive shaft will turn but the wheels will not i have replaced the vacuum switch and it did not work, so now what do i do?
thanks
Old Aug 3, 2010 | 05:01 PM
JohnnyZJ's Avatar
JohnnyZJ
does the light come on? its possible its not completely shifted into 4x4. the light would engage, thus actuating the CAD, but tcase might not be in 4x4. thats easy to check though; pull on the shifter harder.
your problem sounds like the CAD is broken still however. if it makes no noises/sounds etc, its either not in 4x4 or the CAD ain't working.
Old Aug 3, 2010 | 05:29 PM
lifted99ram1500
no the light does not come on and i can pull the shifter as hard as i can and nothing happens same with 4 low.
Old Aug 3, 2010 | 07:46 PM
evans3's Avatar
evans3
could there be sumthin wrong with the linkage? do you have a vacuum at the CAD?
Old Aug 3, 2010 | 08:11 PM
lifted99ram1500
I don't think any thing is wrong with the linkage because the transfer case will engage. And what is a cad?
Old Aug 3, 2010 | 08:55 PM
Central Axle Disconnect. On the passenger side of the axle. Should be two vacuum lines, and electrical connector, and a vent hose coming off of it. Make sure the vacuum lines are hooked up....... Check for vacuum there as well. Vacuum should switch from one line to the other when you shift into/out of 4wd. If vacuum switches, you have an internal problem. If vacuum is missing from either side, you have a leak. (rather common.)
Old Aug 3, 2010 | 08:56 PM
dhvaughan's Avatar
dhvaughan
read this.
http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
Old Aug 3, 2010 | 09:41 PM
lifted99ram1500
should the vacuum be light or should you really feel it sucking?
Old Aug 3, 2010 | 09:51 PM
dhvaughan's Avatar
dhvaughan
it should feel pretty strong, same as a hose up at the intake manifold.
edit - my steel vac lines at the trans cross member were mangled and leaking.
Old Aug 3, 2010 | 09:59 PM
lifted99ram1500
thanks,i must have a pretty good leak because i cant feel any vacuum. but all the lines look ok?
