latest project: ram air hat
#71
Hemifever brought up an interesting point.
He's concerned that the setup may not be making as much HP as the open air hat. The drop in A/F ratio at WOT from 12.8 to 12.3 may mean that less fuel was needed than before, thus there could be less air flowing and less power might be being made.
The cooler IAT sensor temps may not be the reason for the drop in A/F ratio.
Something to ponder.
I was thinking of that when i picked up my two dakota air hats. The filter inside is only 9 inches around. (YEAH BABY!!! I AM STARTING MINE!!!)
Are you using a cloth filter or the paper one?
--Dan
#73
#74
Hey AIM, what type of paint did you use? I have some wrinkle black, but it didn't work out quite like the label. Is that just flat balck rustoleum?
Also, did you use a ivet gun to attach the other snorkel? Or are those just screws? I would like to know the type of screws if you would be so inclined.
Thanks,
--Dan
Thanks,
--Dan
#76
THANKS MUCH. I will be taking my time with this one. First time cutting anything since i cut my exhaust on my 1996 when putting on headers.
Gonna take my time sanding. Thanks for taking the pic.
LET ME KNOW if you want anything from that junkyard. I will be back there next week, to pull some parts. They have LOTS of 2nd gen rams and daks. LOTS. THey are on car-part.com so they probably deliver. I can go scope some parts if you need.
#77
#78
I honestly don't know if there's a bunch of benefit to all the sealing I did, I just did what seemed right. A bunch of it may have been totally unnecessary to any performance gains at all.
When you get the RTV, cut the tip of the tube at a steep up angle and the flat tip will help smooth the RTV, kind of like caulking a bathroom or kitchen.
And get lots of paper towels, that crap gets on everything.
#79
#80
Oh yeah, snag yourself an extra IAT sensor or 2 from the junk yard, you can leave the original one in the manifold to keep the hole plugged and put a new one in the hat for colder temps.
If you find an unbroken not cracked 2001 dash cluster bezel, I'd be interested in that. The one that surrounds the gauge panel. I think the heat in Texas has destroyed all of them here, I can't find a single one
