99 5.9 magnum with 98 5.9 pcm?
Old Aug 7, 2010 | 01:04 AM
1998ram5.9's Avatar
1998ram5.9
Default 99 5.9 magnum with 98 5.9 pcm?
Im getting a 1999 360 magnum with 100,000 on to put in my 98 that already has a 360 in it. I was wondering if i have to change the pcm when i put the new motor in it? I dont think i have to but not sure.
Old Aug 7, 2010 | 01:24 AM
cmckenna's Avatar
cmckenna
That's a very good question. In lieu of that question, I would be looking at the fuel injector specs as well as what other electrical changes and revisions took place at the sensor level for this is where it will / would require either the correct programming or, the correct PCM.
So, the question is: is the EFI system and sensor level identical between those two years?
That's the question: Are there different sensors thus requiring different grounding schemes, different pinout etc etc.
CM
Old Aug 7, 2010 | 10:06 AM
The basic engine is exactly the same. Just put your intake/sensors and such on the new motor, and it won't be a problem.
Old Aug 7, 2010 | 10:20 AM
dhvaughan's Avatar
dhvaughan
+1 to keep everything as a 98.
also, if the new to you 99 engine hasn't already had the plenum fixed, and you plan to keep it, put in a hughes plate while you have it out. if your 98 already has a hughes plate on the intake, just swap it over.
remove or protect the crank position sensor during the swap. easy to damage.
Old Aug 7, 2010 | 05:46 PM
1998ram5.9's Avatar
1998ram5.9
ok thanks guys, and im gonna get the engine and rebuild it in my garage and make it a performance engine. Performance heads, 1.7 roller rockers, all new bearings and and most likly re ring it. Then put some headers on it and most likly a sct tune.
