parts list for engine replacement... anything i missed?
Old Aug 8, 2010 | 11:03 PM
  #21
Part of that procedure is to disable the PCV system. (which is what draws the vacuum on the crankcase.) You WILL see pressure in the crankcase, even on a brand new engine with PCV disabled. There is ALWAYS some blowby. How much pressure built up?
Old Aug 8, 2010 | 11:04 PM
  #22
matty675's Avatar
matty675
What is your oil pressure at idle when the engine is warm?
"something" is probably "new motor", or "rebuild time". Have you done a compression test on the engine? (both dry first, and then wet?)
the dash gauge reads 0psi but its really 3-5psi per a mechanical gauge. never done a compression test. o yea and by alot of oil i mean 1qt per 150 mi. vaccum tests are all good, ik they are not very reliable tho
Old Aug 8, 2010 | 11:05 PM
  #23
matty675's Avatar
matty675
like 2 psi or so. how could ther be vac and pressure in the crankcase at the same time?
Old Aug 8, 2010 | 11:06 PM
  #24
matty675's Avatar
matty675
Originally Posted by lastrights
where are you buying this motor ?
ebay, ive checked out the seller and talked to other buyers. as far as i can see its legit
Old Aug 8, 2010 | 11:18 PM
  #25
Wow..... that's BAD. You should have at LEAST 10 pounds at idle..... if you are below that, then something definitely needs to happen. Might be as easy as a new oil pump... But, if you have a buncha buncha miles on there.... and your oil consumption is that bad with a GOOD plenum........ yeah, new motor, or rebuild time.
Do you have to return your old motor as a core? (I would be interested in it if you don't have to, and you aren't too far away....)
  #26
lastrights's Avatar
lastrights
well make sure you know what kinda cam hes putting in there so you know if ya want to 1.7 HS or a build .. that basically the brain of the engine
Old Aug 8, 2010 | 11:30 PM
  #27
matty675's Avatar
matty675
i still dont understand how ther can be pressure and vac in the crank? yea i do need it as a core sorry
Old Aug 8, 2010 | 11:31 PM
  #28
matty675's Avatar
matty675
what? whats HS?
Old Aug 8, 2010 | 11:48 PM
  #29
Harland Sharp. Roller rockers. Higher ratio than stock.
If the plenum was blown, you would have vacuum in the crankcase, even with the PCV disabled......
Old Aug 8, 2010 | 11:56 PM
  #30
matty675's Avatar
matty675
the tsb said its normal for up to 3 psi of pressure to build in the crankcase so how would a vac/pressure gauge detect vac if ther was pressure arrent they opposites?
