Code P0443
Old Aug 9, 2010 | 11:52 AM
shott8283's Avatar
shott8283
Default Code P0443
I have been fighting this code for a while now and have run out of ideas and options
It is a EVAP Purge Valve Control Circuit malfunction
so far what I have done is
- checked and replaced gas cap
- checked all vacuum lines
- replaced the valve/solenoid
I will clear the code with my actron, and if its while im driving or the truck is running the code will comeback right away. if I do it while the truck is off, the code will come back after two start ups.
i am wondering if this may be a PCM problem. or possible a bad wire going to the PCM. either way, does anyone have a pin-out for the PCM?
Old Aug 9, 2010 | 12:32 PM
There is a factory service manual available for download in the FAQ section of this site, it is for a 2001 truck though. If your truck is 98 or newer, should be pretty close at the very least.
Old Aug 9, 2010 | 12:40 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I bet there's a problem with the hoses or the charcoal canister.
Old Aug 9, 2010 | 03:43 PM
shott8283's Avatar
shott8283
well i found it!
suscribed to all data and got the pin out and the tech manual troubleshoot for the evap purge solenoid. found that the signal wire from the plug to the solenoid to the connector directly to the pcm was broken, cut it at each end and ran a new one. bam!
Old Aug 9, 2010 | 04:11 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Any chance you can post a pic of what you repaired? Mine keeps spitting out an EVAP code which I know has something to do with my canister having been saturated in gasoline a long while back.
Old Aug 9, 2010 | 11:16 PM
shott8283's Avatar
shott8283
yea, ill try and get something tomorrow and post it
Old Aug 10, 2010 | 08:25 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Excellent. Please do.
Old Jan 25, 2013 | 02:21 PM
Brian Shoemaker's Avatar
Brian Shoemaker
New Member
i have a 2001 dodge truck 1500 and i have a code p0443 evap emission conrtol system purge conrtol valve circuit malfunction. how do i fix it?
Old Jan 25, 2013 | 02:35 PM
Grab the 01 service manual from the faq section, in the Service Manuals thread.
Check the valve itself, make sure it is plugged in, and isn't something truly obvious.
