EGR Valve on 2001 5.9
If the CEL comes on, there should be a code stored. Sometimes "soft" codes can even be stored without a CEL, but not the other way around. Thats just weird.
Ideas for you to check, off the top of my head:
-Busted plenum gasket
Take off the air cleaner assembly and look into the intake manifold, past the butterflies. Any oil in there? If so, probably a leaking gasket. Very common on our Magnum V8 engines. You can do a search of the forum for more info on that, its been covered lots of times.
-Oxygen Sensor
As someone already said, could be a bad O2 sensor. However, that would usually trigger a trouble code.
Did it start doing this before or after you did the tune-up (wires/plugs/rotor/etc.)?
-Oxygen Sensor
get new cats or hollow them out. My 5.9 is a 2002 but had the same problem it would stall every 3 minutes, ever since I hollowed mine out it’s been running amazing. Give it a try bud
The following users liked this post:
MoparFanatic21 (07-05-2021)
