Egr & headers ***help***
Old Aug 11, 2010 | 07:32 PM
Pacmanloads's Avatar
Pacmanloads
Default Egr & headers ***help***
I have a set of Pacesetter long tubes that have arrived and i will be installing them in the next couple of weeks. For the past month or so I have been spraying my cast manifold bolts with penetrator to have better luck taking the old bolts out and noticed that I have an EGR Valve that is hooked to the passenger side manifold down by the firewall . I am not at home to see if the headers have a port for that but I will assume that it does not. My Question is ...."Can I delete the Egr by unplugging the electrical and covering that port with a bolt on plate....and will it still run right? Any help would be appreciated. Thanks in advance
Old Aug 11, 2010 | 07:36 PM
GeorgiaDodge's Avatar
GeorgiaDodge
i did an EGR delete along with a Smog and vacuum delete on my old mazda. Not 100% sure about on a dodge, It might throw a code but i dont see it hurting anything.
Others please correct me if im wrong
Old Aug 12, 2010 | 12:32 AM
Pacmanloads
Thanks Georgia.......anyone else?
Old Aug 12, 2010 | 12:50 AM
GeorgiaDodge
forgot to mention, some of the longtubes i have seen before have had EGR ports as well as o2 ports. I have short tubes so im not to familiar with long tubes but you might want to look at them and double check
Old Aug 12, 2010 | 12:57 AM
Pacmanloads
Will Do.....just wasn't in the description when i purchased them...and I havn't seen them in person yet....just an assumption.....would be great if they just had the port . Thanks again.....I will let you know and will post some pics of the install and a short video of sound .
Old Aug 12, 2010 | 03:25 AM
dakotas ram's Avatar
dakotas ram
i have pacesetter shorties that i got for free and they didnt have the egr port, i made a plate but left all electronics hooked up....runs fine and only get a code every great once in awhile
Old Aug 12, 2010 | 11:31 PM
Pacmanloads
Thanks.....that is what i will do if they dont have a port.
Old Aug 12, 2010 | 11:52 PM
I wonder if a tuner could 'leave out' the egr portion? But, the 95 is OBDI.... so, you would have to have a chip custom burned..... probably not worth it.....
Old Aug 13, 2010 | 02:37 AM
dakotas ram
found this interesting write up about egr, if you dont read it all at least check out the "other notes"
http://www.thirdgen.org/egrdiagnose
