Shaking at 35 to 45 mph
Old Aug 14, 2010 | 07:39 AM
trucker70's Avatar
trucker70
Default Shaking at 35 to 45 mph
hey yall have 99 ram 2500 with a 5.9 starting to shake about around 35 to 45 miles per hour then goes away at 55 then feels like its trying to change gears every so often any ideas thanks for any help
Old Aug 14, 2010 | 08:37 PM
jasonw's Avatar
jasonw
Site Moderator
I will move this to the 2nd gen section to get you some help. Welcome to DF!
Old Aug 14, 2010 | 09:46 PM
Darrell67's Avatar
Darrell67
Have you checked your u-joints?
Old Aug 14, 2010 | 10:38 PM
trucker70's Avatar
trucker70
I have'nt checked any thing yet just wondering what anyone might think.I will check though and thank you all.Also I heard that it might be the throttle positioning sensor,does that sound like it may be.Thanks for the help,James
Old Aug 15, 2010 | 10:59 AM
Sheriff420's Avatar
Sheriff420
Wheel balance being off will cause bit of a shake/vibration from 40-50mph (45mph is the worst).
Rotate your tires and see if the shake changes at all.
Old Aug 16, 2010 | 12:52 PM
JohnnyZJ's Avatar
JohnnyZJ
ujoints don't cause shaking. why would you suggest it?
is it a vibration or bad shake or a death wobble?
chances are its a bad wheel bearing/tierod/balljoint. try the cheap solutions first, like sheriff said, change the front tires to the rear. if the problem goes away, a bad tire/balance could be the culprit. if not, then you have to take a look. have someone wiggle the steeringwheel back and forth; check the balljoints/tracbar, tierods for movement. if something has play in it, that could be a problem. also, jack the front end up and grab the whee; give it a shake. there should be 0 play in it. if it moves at all, somethings gone (balljoint or unitbearing)
Old Aug 16, 2010 | 02:51 PM
95RAM360's Avatar
95RAM360
tracbar.....look on youtube and search "Death Wobble"....thats what i think it is.
Old Aug 16, 2010 | 03:39 PM
charlie1935's Avatar
charlie1935
I have had U-joints cause vibration which is a fast shaking.
Old Aug 16, 2010 | 04:04 PM
Do you feel the shake thru the steering wheel? or your butt?
Old Aug 16, 2010 | 07:21 PM
charlie1935
All according to where the bad U-joint is.
