Old Aug 13, 2015, 08:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
ram headlights no workey
Old Aug 16, 2010 | 12:41 PM
JohnnyZJ's Avatar
JohnnyZJ
Default ram headlights no workey
99 ram. almost giving up on this truck.........
so, headlights don't work. i have replaced the DRL module, the switch, and the headlights.
problem.. daytime running lights DO work. as do the brights. the low beams do not work. when i click the low beams on, the dash lights up still; but no lights. when i unplug the DRL module, the brights will work, but not the low beams.
now, heres the kicker; i busted out my tried and true test light, unplugged the bulb and testted the socket. i get power to all three sockets. so; where next? bad ground? where to the headlights ground too?
any ideas?
Old Aug 16, 2010 | 12:50 PM
Maxx_Magnum's Avatar
Maxx_Magnum
what switch did you change? The hi/low beam switch likes to go bad on these things also, fairly common problem around here. Take the kick panel off and search around for breaks, etc. where the column tilts
Old Aug 16, 2010 | 08:51 PM
kissmymagnum's Avatar
kissmymagnum
X2 on the dimmer switch (part of the turn signal switch... also known as a multifunction switch) That sounds like the most likely source of your problem.
Old Aug 17, 2010 | 01:48 AM
JohnnyZJ's Avatar
JohnnyZJ
is that the guy in the steering column? i swapped the one in the dash (the switch that turns on the lights) but not the steering column.......... too bad i didn't jack that off the Durango when i was at pnp...............
i hate electrical gremlins!
Old Aug 17, 2010 | 09:37 AM
jasonw's Avatar
jasonw
Site Moderator
Yep, the one in the steering column.
After you swap that one, let us know if they still don't work right.
Old Aug 17, 2010 | 09:56 AM
Maxx_Magnum
Also, I don't suggest getting the switches from a JY, as this is a fairly widespread dodge problem, so you're likely to get another switch that is either bad, or will go bad sooner than you think. Just a heads up, we've seen this a thousand times
Old Aug 18, 2010 | 10:38 AM
JohnnyZJ's Avatar
JohnnyZJ
stupid question but why would that cause headlights to not work? i'm stuck at a desk and can't do anything till tonight anyways........
Old Aug 18, 2010 | 12:29 PM
Contacts go bad. Parts in the mechanism that switches circuits break. Etc. I turned my headlights on the other day.... and.... no headlights. Tried the high beams, they worked, switched back to low beams.... they worked. I am betting that I am going to have to replace that switch soon.
Old Aug 18, 2010 | 04:56 PM
calgaryman's Avatar
calgaryman
We should just sell our trucks as a package deal... one good truck, one parts truck
now which one is the good one
Old Aug 19, 2010 | 10:24 AM
JohnnyZJ's Avatar
JohnnyZJ
neither
dodge BBQ? collect insurance money?
